Looks good. I like the blue, chrome and stainless look.
Creamy
Originally posted by jaywish View PostYou needed that hole in the hood. Very nice.
Because of the carbs interfering with the wiper linkage. Had to machine two 2" carb spacers down to 1 3/4. If the wipers were removed at least the drive arm no hole would have been needed. Realy would have liked to not have had to. Would be even more of a sleeper.Scars are tatoos of the fearless
Could you tell me more about your fuel system? I don't know anything about carburetors so I don't know what I'm looking at except lines running to things I don't recognize. Is that a pressure regulator and a filter?
Is it a 2x4 or 2x2 setup?sigpic
Originally posted by 1990LTD View PostCould you tell me more about your fuel system? I don't know anything about carburetors so I don't know what I'm looking at except lines running to things I don't recognize. Is that a pressure regulator and a filter?
Is it a 2x4 or 2x2 setup?Scars are tatoos of the fearless
Originally posted by turbo2256b View Post2 4bbl regulator to the left of the master cyl filter to the right on the inner fender
thanks! I guess I had it right. Did you make up the bracket for the FPR?sigpic
Originally posted by turbo2256b View PostThis camera will do closeups so some good pics of my switch plates with real burrled walnut inserts.
[ATTACH=CONFIG]32152[/ATTACH]
[ATTACH=CONFIG]32153[/ATTACH]
VERY nice, clean work!! Bobby
That is pure SEX!!!'88' MGM wagon (mine and my sons toy)
"60" chrysler New Yorker (my project)
"78" Chevy 1 Ton P/U (yard horse)
"01" Ford Explorer (wifes DD)
"93" Chevy Suburban (my DD)
Had to replace the U-joints. Front one had dammage between only one cap and the cross post (a bit odd).
The rear joint looked ok but one of the hoops in the flange was dammaged and the cap was loose in it. After removing the clip the cap just fell out instead of needing pressed out. Should mention the slip yoke isnt one from a AOD havent been able to find what tranny it is used in. Same issue with the torq converter.
I think you had no real problems with your U-joints and that your real intent was to show off that shiney driveshaft to all of us with our rusty stock unitsBut, I love reading through your thread and ogling Creamy any chance I get anyways
