View Post
The MegaMerc
Good luck Jim.
Always afraid of that happening to me.~David~
Thanks David, pin came right out. Awesome tool. Details later....
While the rear was apart & waiting for tools I replaced the plastic pucks in 3 of the windows.
Originally posted by mitymerc View PostThanks David, pin came right out. Awesome tool. Details later....
While it was down for the rear I replaced the slugs in 3 of the windows.
The MegaMerc plunked (passed/flunked) inspection on Friday.
The tierod ends are ready to pull, still need to remove them from the sleeves. Moog ends should be here on Friday.
Sleeves are cheap enough, buy new ones if the outer TREs are too stuck in the old ones. I don't even fuck with them on older cars, if she's getting new TREs she's getting sleeves ordered too, then if I gotta go for the blue wrench to make the outer TRE let go of the sleeve I'll pull the sleeve off the inner TREs.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Removed old TREs last night. Copious application of P'Blaster, a couple good whacks on the spindles & they disengaged. A small pipe wrench on the sleeves wedged into the springs & a bigger one on the TREs turned them right out. Awaiting new TREs...
Back together & on the road. Job went amazingly easily for such an old beast.
Now it needs Explorer subs and amps?The ones who accomplish true greatness, are the foolish who keep pressing onward.
I also don't like to fool with the sleeves. Most of the time they end up mangled by the time the end comes loose.86 Lincoln Town Car (Galactica).
Originally posted by his royal ghostliness View Postnow it needs explorer subs and amps? :d
To answer your question in the other thread, idk for sure how to make these things work with the premium sound. What I started with is a head unit with two pairs of wires, each going to a speaker in the doors - that's all Ford deemed necessary to provide my vehicle with. I replaced the factory head unit with an aftermarket one that supports four speakers and has separate RCA sub outs, and added wiring accordingly. In case of Premium sound with factory head unit, I suppose you could parallel the amps for the Explorer subs with the rear speakers, very much like how the dash speakers are paralleled with those inside the front doors. Actually in your case that is going to be the easiest solution, since your rear speakers are right there near where the subs will be as well. Then you also need key-on signal, power, and ground - so total of 5 wires per amp.The ones who accomplish true greatness, are the foolish who keep pressing onward.
I had figured parallel so as not to disturb impedence. I really don't want to put much $ into sound right now so fact head will have to do. I have wanted to put an 8 or 10 under the rear panel between the storage cubby & the speaker. Seems like an impossibility to build a proper erly sized box to fit there. Now that the boys have outgrown the wayback seat the cavity is available.
