View Post
The 1992 Grand Marquis
I can get you the 93 diagram if you want.
thought you had the 92 EVTM ?86 Lincoln Town Car (Galactica).
There's a lot of stuff for diagnosis of the EVA. Up to 6 PDF's so far.
Originally posted by sly View PostThere's a lot of stuff for diagnosis of the EVA. Up to 6 PDF's so far.
The rest is mainly wire testing.Last edited by sly; 11-25-2021, 03:42 PM.
That looks about right from what I remember. If i had to lay a wager on the problem, its probably missing VSS input.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostMine groans and mumbles in the Towncar. I'm real tempted to un-do the mod, but I need some steels to put back in there. Tired of it sounding like cheap shoes on a wet floor every time I make a turn at slow speed.
Not any help on the GMQ's variable assist issue, never messed with that stuff. Kinda want to though, however that would likely require some GM parts unless someone knows of a Ford vehicle that was equipped with the variable assist AND hydroboost at the same time?The ones who accomplish true greatness, are the foolish who keep pressing onward.
6 new clutches and 2 old ones. I remember beating those gears into place. Pretty sure we destroyed the brass punch in the process. Its too tight, whatever it is.86 Lincoln Town Car (Galactica).
Originally posted by 86VickyLX View PostYeah that's why. Gotta reduce the shims if possible. F150 spring too? lol
In any case, with a factory S-spring in there I'd suggest ditching the 2 used clutches and running just the new ones, should be able to actually keep the current arrangement and just pull the outer-most clutches and replace them with a pair of the thick (.050-.060) end shims - this will provide 6 friction surfaces (as opposed to 7 in the typical 4-clutch setup and 5 in the factory 3-clutch) and tighter action but without the ridiculous initial preload the car seems to be suffering from now. Happy medium more or less, but still a bit on the performance side.
If however that thing does indeed have an F150 spring... going back to full factory arrangement will probably be best.The ones who accomplish true greatness, are the foolish who keep pressing onward.
So I checked wiring for VSS. The ohm reading was 217 ohms. Which is pretty close to the vss that I have out of the car at 197 ohms. So VSS is hooked up. For shits and giggles I ohmed out the EVO solenoid... OL... I ohmed the other one 65kohms. So like I said before. I need a working EVO solenoid for a 1990 Lincoln TownCar. Who gots?
The Mark VII has a stock traction lock rebuild with new clutches. it works silently, which is why I'm thinking going back to stock is the way to go if I can figure out which clutches are new and which are old.
anyway, EVO is OL directly on the solenoid, or through the wiring?86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postno, after launching that mofo across the shop a couple times, we gave up. Also, we couldn't find it. its probably somewhere up there still.
