I believe I have introduced my 1992 Mercury Grand Marquis before but I am gonna do a 302 swap in it and would like to give a history of it before.
I bought this car on October 10, 2010. It had a damaged AOD transmission, the usual TV cable. I bought a used AOD from craigslist for about 60 bucks. Used that to rebuild mines.
Here is a picture of when I bought the car.
The transmission was rebuilt with a haynes manual. Although it is not the best I also used a video series from youtube from the user bah53 to get an idea on how to rebuild it. The car had several problems so I had to fix that and the paint was also damaged. So I decided to go with rustoleum flat black. I was quoted 3000 for a gloss black paint job and being this was a 700 dollar car I didn't see it as being worth it. So rustoleum was just 30 dollar a gallon and it couldn't get worst.
The fender had to be replaced since they were rotted at the bottom.
After That I decided to put a basic car alarm since after I painted it someone scratched the paint with a piece of stone. That was at my Highschool. I got angry.
Recently I just replaced my stock 15 inch rims with 16 inch interceptor wheels or the basic wheels for a crown victoria. Also I used Mountaineer hub caps.
So, finally after a year I am starting to save up since I need to repair other stuff on the car to finally replace the engine and drivetrain.
1.For the engine I will be going with a 302 engine. Would go with a 351 but fuel mileage might be an issue. So I am planning on upgrading cams, Intake , Ignition, and exhaust. But right now I am not sure if I should search for a used engine and build it or just buy a new one. I want to leave this engine ready for in case if I just want to supercharge it or put nitrous.
2. For the transmission I will use 4r70w parts to increase the ratio. But will also change valve body to make it be able to change gears manually. I know I could go with a manual but I do city driving and I don't want to worry about changing gears and pressing the clutch. So I am going to prep the AOD
3. Rear differential I will go with either 3.55 or 3.73. 4.10 will not be a good idea since it will accelerate faster but will be limited to a certain amount of speed. will also rebuild the differential completely.
4. For the ECU I will megasquirt in case If I ever want to tune it for supercharging it.
5. I will upgrade the front suspension with 98+ parts. The rear brakes will be replaced with vented brakes and new brake lines will be installed.
There will be more updates to be done. But now the collection of parts begin. Every time I buy these parts I will post. This won't begin until around September or October. But I am finally beginning to do it.
