Did this car spend it's entire life in Florida or elsewhere? Perhaps there is a reason for so much rust as I have never seen it down here.
1992 Mercury Grand Marquis
Originally posted by DerekTheGreat View PostJesus, all this rust in FLA? My dad has a place damn near right on the water but I never see cars with any rust on them when I visit. Certainly nothing like we see here in MI.1992 Mercury Grand Marquis.
Upgrades: Big Brake Upgrade, digital dash, Custom ignition Switch system, sequential tail lights, Teflon Fuel lines, LED interior lights, rear end rebuild with limited slip.
Future upgrades: 5.0 swap, 4r70w swap, aluminum driveshaft.
- Likes 1
Originally posted by friskyfrankie View PostDid this car spend it's entire life in Florida or elsewhere? Perhaps there is a reason for so much rust as I have never seen it down here.1992 Mercury Grand Marquis.
So, quick update. Trying to make these more often. Just bought a few more things for the Manual Swap. Just got a brand new flywheel and clutch for the car. Also doing maintenance items on the engine. New Intake,water pump, rear seal, Oil pan gasket, Timing cover gasket, and a timing chain kit. Going to be taking out the engine since I want to paint the engine bay and reinforce the firewall for the clutch. It became on of those since I am there might as well do. Also worked more on the rocker panel. The replacement rocker panel is nothing like the factory one. Have to weld it on top of the old metal. Not ideal I would think but it'll be covered. Once I finish the welding going to do some Bondoglass to make sure there wont be any issues with it reacting with humidity.
3 Photos1992 Mercury Grand Marquis.
- Likes 1
There is no humidity in Miami……~David~
How are the inner rockers? Mine are MIA on the 88.1990 Country Squire - under restoration
Originally posted by Tiggie View PostHow are the inner rockers? Mine are MIA on the 88.1992 Mercury Grand Marquis.
Originally posted by 87gtVIC View PostThere is no humidity in Miami……
