1984 Grand Marquis
    Thanks tristar
    Motor City Patrick
    1988 MGM
      79-91 = box (80-89 for Lincoln)
      92-97 = aero (90-97 for Lincoln)
      98+ = whale
      67-78 = barge
        you can always refer to the trusty chart
Name:	panther platform.jpg
          Thanks
          Motor City Patrick
          1988 MGM
            [ATTACH=CONFIG]38169[/ATTACH]
            That chart is wrong though, the PI p71 designation didn't come out till 93. (Though I believe it was used in the VIN's beforehand for something else)
              67-78 = barge
              Just a note, 67-78 (Lincoln to 79) aren't Panthers.
              Past Panthers
                I think Sly already knows.
                '79 Continental Town Car
                '90 Crown Victoria LTD
                '94 Crown Victoria
                  yeah, but we use the term around here... so it's good to let newbies know.
                    I figured but just didn't want anyone else to be confused.
                    Sly, wasn't trying to be an ass......
                    Past Panthers
                      '94 Crown Victoria
                        Easiest way to replace pcv on a 88 Marquis?
                        Motor City Patrick
                        1988 MGM
                          Motor City Patrick
                          It's down behind the upper intake, way down in there. Replace the breather screen and rubber grommet while you're in there.
                          It may annoy some folks when you come into threads and just start asking questions about your own stuff. Just a head's up.
                          Search around, I think you'll find quite a bit about "the PCV trio" on the 86-91 SEFI Panthers.
                            easiest way? pull on the fat hose going down to it. Should lift it out. Use a pair of pliers or long sheetrock screw to remove the screen after pulling the grommet out.
                              I got a new grill a couple weeks ago from Mainemantom and I put it on last week sunday.
                              Old grille:
                              New:
                              I also treated her to a new air cleaner today from pep boys:
                              I've been eying up a new air cleaner for some time and came across this a few weeks ago on summit/jegs. I had plans on buying it online sometime this week but I didn't know pep boys sold the one I was looking for. Apparently they have a 'speed shop' now (haven't been in there in almost a year) with all that stuff instead of the one shelf with an edlebrock intake, cam and valve covers.
                              I also put in leather seats that I got from pantera77. I will post pics as soon as I get the back of the back seat on. I broke one of my cheap torx bit tying to take out the bolts that hold it on. Hopefully tomorrow I'll be able to take care of that with the good ones I took from work.
                              Now I've gotta decide wether or not I wanna get chrome or Ford Racing valve covers.
                              '93 T-bird
                              '03 Silverado ECSB
                              Missed:
                              '88 Mark VII
                              '86 CV
                                Much better! The '79-'82 grille is my all time favorite.
