View Post
1975 Ford Maverick
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
They are unfortunately not scorpion...they have no name brand printed on them, but they do fit under the stock aluminum HO valve covers
Mitymerc: Thank you for helping confirm my suspicion about how fast this car is, of course there is no real way to know until I take it to the track
Bit better photo of the damage:
Originally posted by Bobcat View PostCouldn't you use spacers? That is if you want to just preserve the look of just not wanting to spend money. I agree with either
I have taller valve covers actually. They came with the heads. I think it might need an intake spacer, but honestly I would prefer to keep the stock ones. The fill holes are in the wrong spot on the other valve covers if I remember right. They're not terrible looking at least, its a decent aluminum cover, not the shitty stamped steel kind. I kind of dig the stock look on that car. Besides, I'm terrible at keeping shiny stuff polished, so not having to worry about it appeals to me.86 Lincoln Town Car (Galactica).
Originally posted by Brown_Muscle View PostThey are unfortunately not scorpion...they have no name brand printed on them, but they do fit under the stock aluminum HO valve covers
[ATTACH=CONFIG]41583[/ATTACH]__________________________________________________
Originally posted by Bobcat View PostWhat damage, Philip
If you cut out all of the baffling.-Phil
Originally posted by 86VickyLX View PostIf you cut out all of the baffling.
oil fill tube... looking for that greased lightning...
if the baffles are hacked, you'd see more stuff down the tube. You also tend to get more oil up the tube and into the throttle body.86 Lincoln Town Car (Galactica).
Yup, by just grinding the bottom of the baffle it still functions, but nosy guys see nothing.....
This was many years ago, but it just came to mind that I may also have tried double vc gaskets also.....
Originally posted by gadget73 View Postspacers for what ?
.__________________________________________________
valve cover spacers exist? I thought you meant intake spacers for taller valve covers.86 Lincoln Town Car (Galactica).
apparently they do.. http://www.jegs.com/i/B-B/128/63940/...oductId=747514
inch and a quarter thick and only 130, plus I have to use 2 sets of valve cover gaskets at 40 bucks a pair for good ones and my own valve covers and probably at least a 1" intake spacer. Not a bargain I'm afraid. I can get whole valve covers for that or less and only need a single set of gaskets. I had no idea such a thing even existed though.
I actually have a set of taller valve covers around here somewhere. Decent aluminum ones too, but I think the filler hole is in the wrong spot.86 Lincoln Town Car (Galactica).
