It is the green wire! huzzah. My interior is still in pieces but the needle bounces with the rpm now. Ill take pictures whhen it is toggether.
I bought a box!
Originally posted by killgore View Post1985 LTD Crown Victoria - SOLD
Originally posted by killgore View Post..So much more comfy than all my other friend's cars.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostThis. I find it hard to be a passenger in most modern cars now that I've been driving one of these steadily for the past two years.
Hey guys, what is a good front speaker for these things.
I am not looking for something perfect sounding, just something nice enough to match the rear "premium speakers" that came out of my 94 Lincoln. And since I have no front speakers I can't really go backwards.
To match that I'd throw the premium ford or JBL/Ford 5.25's in there, less than 10 bucks all day long at a junkyard. Consensus around here is that the premium Ford door speakers are the same as the JBL/Ford door speakers. I have both and physically they do look a like, only the Ford/JBL one has a specific sticker on it. If you prefer to go aftermarket I recommend JBL power series stuff. I put 6.5" ones in my doors and should've went with 5.25's. PITA to get them in there and couldn't use the factory holes or plastic bracket at all.1985 LTD Crown Victoria - SOLD
I have under the dash speakers. Is there a spot in the door for these? Because if so I have a nice set of kenwood 6" that do not fit in said dash.
I also have a really nice set of audio technia 6x9s that I wouldn't mind stuffing somewhere. The door speakers in my 94 were not the premium sound speakers but the rear ones were. It was weird.
you'd have to run the wires down from the dash location, but yes, there's a 6.25" hole in the door behind the paneling. Most of us that use those locations just cut a hole in the panel. I have the pockets on my door which helps hold the panel down because all the panel clips are shot, but as you can see... there they are. I did have to pull the dash pad and get the wires off the stock dash speakers and pull the connector down below the dash and run wires into the doors, but it was worth it.
