Just had the fuel pump relay replaced. Car was having intermittent starting/running issues. I hope it will be reliable now! Next plans: undercoating and get a set of winter tires.
My 1994 Crown Victoria
Good show!************************************************** ******************************
1997 Crown Vic - Mostly rust free, moderate mileage. On the road... but far from perfect. **SOLD**
1985 Crown Vic in 2-Tone Blue **SOLD**
http://automophiliac.blogspot.ca/
Back in service!
The shift tube broke last month, shortly before Christmas...I had my car towed to a transmission shop who verified the problem but they didn't want to do the workSo I had to get my car towed AGAIN. I had the Ford dealership do the repair. After all was said and done, the bill was almost $400 but now the shifter works perfectly!! Fingers crossed that there won't be anymore repairs needed for awhile.
'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
It's been a while!
I bought a new gas tank and straps back in April. Got a shop to install the parts last week. Inspection is due next month and it should pass. The heater core still needs to be replaced. Planning to have that done by the end of the year...'79 Continental Town Car
'94 Crown Victoria
Originally posted by 79lincolnlover View PostInspection is due next month and it should pass.Last edited by 79lincolnlover; 09-26-2017, 10:22 PM.'79 Continental Town Car
'94 Crown Victoria
It was a good day!
The frame and cross-member have been repaired. Old metal has been cut out and new metal has been welded in. Was undercoated after. Set me back $460 after tax. Scored a heater core tonight for $20: https://www.kijiji.ca/v-engines-and-...box/1302437975
Will have it installed within the next few days'79 Continental Town Car
'94 Crown Victoria
May she live on!~David~
I think I'd be looking into the internal frame rail rust converter stuff. Eastwood sells one, basically its a spray can with a long-ass tube you shove down through an opening and it coats the inside. Maybe not perfect but its better than nothing.86 Lincoln Town Car (Galactica).
Man, that rot was pretty advanced. That is actually worse than my Town Car, though the hole in pretty much the same spot on the torque box is getting rather large. I'm not sure I've ever seen the trans crossmember rot away like that on an Aero/Whale, seen lots of boxes do that tho. I may see if I can get a shop to fix my frame, but the rest of the car is rough enough that I'm not sure I want to sink the $$ into it which is why I replaced the car already, but it just won't die.-Steve
