I would have to own a small garage just to service my own vehicles if I lived up there.
My 1994 Crown Victoria
service up-date
Work order:
-Check coolant level & top up.
-Tested battery for draw and traced it to the auto-start module, which was then removed.
-Replace valve stem on the driver's side front tire.
-Install y-pipe.
-Install rear coil-springs.
-Checked body for rust. Will need right rear rocker panel replaced to pass mvi in November.
I have the body repair appt set up for next week. Repair estimate was only $200. Same shop that fixed the rocker panel on my '90 Crown Victoria a few months ago.'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
Any paint and body work for $200 is a deal.1990 Country Squire - under restoration
service up-date
The inspection was done a couple of weeks ago. Everything passed! Work order:
-Install new odometer gears (I ordered them from www.odometergears.com, back in October.)
-Check coolant level and top up.
-Oil change.
-Install new rear shocks.
-Install Winter tires (4th season of use but still lots of tread left.)'79 Continental Town Car
'94 Crown Victoria
Good to see an aero still in daily use. They are getting unusual.1990 Country Squire - under restoration
True! There's only 2 aero CVs, 1 aero GM and 2 aero TCs, which I know are still road-worthy in my area. Two of them are owned by an elderly collector, whom I've introduced myself to.Originally posted by Tiggie View PostGood to see an aero still in daily use. They are getting unusual.'79 Continental Town Car
'94 Crown Victoria
service up-date
I was wrong about the Winter tires...There wasn't enough tread left, so the shop disposed of them. Work order:
-Install Summer tires and wheel covers.
-Oil change.
-Install new rad hoses.
-Top up coolant.
-Brake system flush. I took it back a few days later because there was still some air in the system. The brake pedal felt spongy.
There's a rust spot on the driver's side fender lip, which I'm planning to get fixed at some point this year. Inspection is good until 2022 but I'm not going to wait that long to get the bodywork done.'79 Continental Town Car
'94 Crown Victoria
