Originally posted by TecNickal
View Post
My 1987 Mercury Colony Park
My Cars:
check for loose spark wires. I've had some jump off plugs because of getting put on when cold out. There was enough air expansion to pop one off.
Pulled codes 34 and 67. I'm checking plugs right now.
My Cars:
Code 67 is probably because you had the AC on during the self test.
Code 34 is something to do with the EVR, EVP or EGR.
If vacuum is good to the EVR and EGR, then suspect either a failing EVR, or the EVP is saying that the EGR is not fully closing. May need to be removed and cleaned. Carbon loosening up...-Nick M.
Columbia, SC
Yanked a plug from the passenger side rear bank. Greeted with a copper core Autolite 2545. Looks like there's no suspicious fowling on the plug.
However, it does look like the gap is a bit wide, unless that seems about right for .050. I didn't bring my feeler gauge, so I'll check next time. I think however it might just be time to change the plugs and wires. I'm considering using Autolite AP5145 plugs, which are the full thread variant that superseded the 2545 line. I'm thinking a platinum plug will be nice to use since they last longer than copper plugs and this car isn't being driven like a race car normally.
Inspection of the cap and rotor indicated nothing out of the normal.
Originally posted by TecNickal View PostCode 67 is probably because you had the AC on during the self test.
My Cars:
done? nah... plenty of life left. Bend the gap back down a little and run another 30K.
Zach now I'm puzzled. I could have sworn I put Motorcraft platinums in that wagon.
But now I have vague recolection I may have put Autolite coppers in there, or those plugs came with the wagon. I know I did Motorcraft wires at least. Too many dang cars to keep track of - that's why I have a binder that I write stuff down in now so I can keep better track of things. The 89, 90 are the thickest binders lol
Sorry if there was any misleading by me.-Nick M.
Columbia, SC
Originally posted by TecNickal View PostZach now I'm puzzled. I could have sworn I put Motorcraft platinums in that wagon.
My Cars:
I'm not overly in love with platinum plugs. I've run them before, and honestly got anywhere from no benefit to it ran worse. Basic Motorshaft copper plugs seem to be the winner in these.86 Lincoln Town Car (Galactica).
And don't run copper on coil pack ignition. Found that out the hard way.1993 Ford F-150 Flareside - July 2010 - August 2013
2004 Ford Mustang - September 2013 - February 2018
1987 Mercury Colony Park GS - August 2015 - Present
2018 VW Golf GTI - February 2018-February 2021 (was a lease)
2003 EZGO TXT - March 2015 - May 2019 (it's road legal!)
2019 VW Golf Alltrack company provided April 2019 - Present
2012 Fiat 500 5 speed - January 2021-Present
2003 Audi A6 Allroad 6 speed July 2021-Present
or coil on plug. Need plats for that.
The '97 only gets double platinum thanks to that waste spark setup.
So on the '87, would it just be reasonable to use copper spark plugs over the platinum plugs? I usually use platinum plugs simply for the purpose of longevity and most new applications take them anyway.
My Cars:
Yes, copper is what they called for and like best. Conducts electricity better than platinum anyway. I really think you can squeeze more than 30k out of 'em too as my car had 20+ years and 86k miles on it's original wires & plugs. You should have seen all the aluminum oxide under that dizzy cap and such.1985 LTD Crown Victoria - SOLD
Copper it is then. I'll probably grab Motorcraft copper plugs; if not those, Autolites.
Is there any torque specifications I should be aware about for the spark plugs going into the heads? I'm used to very low torque ratings on the 4.6 engines to prevent over-tightening since spark plugs don't need some Hulk-spec tightening on aluminum heads. Would I be safe just to stay in the 7 to 15 FT-LBS range when tightening?
My Cars:
