Does the intake only have two threaded holes for the intake plaque? If so..bummer.
The Blues Bison
Exp intake, just 2 holes. I may tap it @ a later date. The other screws are safe in the glove box.
That would bother me. Id drill and tap for sure.~David~
Originally posted by mitymerc View PostYeah, I spent some time with it too.
Isn't that the year working on cars was banned @ SF? You had something to do with IIRC LOL.
I'm sort of thinking that next time I have to do a tank, I'm pulling the studs and making new, longer ones. Allthread should be fine, just making the things an inch longer would make life a lot less difficult.86 Lincoln Town Car (Galactica).
I remember seeing stuff about Ford selling replacements that are really long but notched so that you can break off the excess after installation. Dunno about model years etc.
Originally posted by IPreferDIY View PostI remember seeing stuff about Ford selling replacements that are really long but notched so that you can break off the excess after installation. Dunno about model years etc.
I looked into it & they do have extra long studs with a weak spot built in. I did not want to wait for Ford to order them & used threaded rod. Hindsight I should have ordered the correct part. It looks like a ghetto rig.
Luckily you can't see it unless you are under the car.
Front wheels came in today.
First time it has been on the ground since reg ran out in '10.
Roughed in the dist & she fired right up, base timing now set to 14°.
Hope to get it registered tomorrow.
Also added a third rib to the roof rack.
Reg'd & ins'd om Fri. Was going to get in inspected on Sat, HOWEVER, on my test drive it would not shift out of firsr AND when I parked it fuel was pouring out above the pass rear wheel....
Keep at it. I wanna see this car in the light!~David~
Go to the light.
Go to the light.
Go-o to de lite.
Fuel leak resolved. One more quart of ATF did the trick. Still shifts softly, have to look @ TV cable.
New wheels will go on after inspection as PA doesn't like spacers over 1/4".
BTW, the tach sig comes from green/LT grn right?
Everything but the drivers door lock works.
Tailgate window is sluggish.
AC is not as cold as I remembered it to be...
