So i was having a problem with fluctuating fuel pressure. The fuel system was as follows:
New 1986 LTD wagon gas tank and fuel pump hanger
AN-6 ptfe supply and return lines
Aeromotive billet fuel filter
Aeromotive billet fuel rails, bypass regulator, 30lb injectors
The stock fuel pump hanger lines are 3/8 supply and 5/16 return. Except that they "neck down" at the ends, making them effectively 5/16 supply and 1/4 return.
1/4" return line was creating my issue, tested by removing the return line from the tank and running the car with the return line in a bucket. I was initially going to try 37 degree double flares and tube nuts on the stock lines. But the bends in the stock lines prevented me from getting the dies on the lines. Did not want to try un-bending the lines and risk kinking/weakening the tubing.
Then looked into trying to add bulkhead fittings to the stock hanger flange and crimping off the stock lines. But the stock hanger flange has a "stepped down" area making that nearly impossible. Trying to heat everything up to de-solder was also not an option, due to the plastic electrical connector built into the flange.
Basically every possible solution i could think of ended in a roadblock. So it came down to fabricating my own fuel pump hanger.
I started with making 2 round discs from 20 gauge steel. Very close to stock thickness. 1 disc was for the flange, the other one was to keep the fumes at bay in the garage.
Stock hanger is the usual setup- supply and return lines, gauge sender, float, etc, i removed the bottom part that supports the fuel pump.
It took me a couple tries to get the flange perfect, my electrical bulkhead needed a 10mm hole (from australia) and i don't have a 10mm bit so i overshot that lmao. Bulkhead holes are 3/4" for the nylon washers. Was ultimately able to use 25/64ths drill bit and sneak up on it with a file.
Used 1/4 x 1/4 square steel tubing, measured carefully and welded on the stock fuel pump mounting piece
