Nice! Any chance I could get a copy of the high-res versions of those?
Blaze's 86 SVt Vic (The on-going project)
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
whoever took those pics know what they're doing.
i was looking through some threads and i think i found a good lil reminder of the shit you had to go through
http://www.grandmarq.net/vb/showpost...7&postcount=18
Glad that car is still here!Ont And Canada PPL The Cookhouse in Dwight
91 Grand Marq . . . . . . 88 ho wagon (project) . . . . . . 80' Lincoln Mark VI
It's been a while I know, but I finally got around to doing a rear disc conversion on the Vic. I got the setup from a 94 Vic in the parts yard. I used new police model calipers (metal piston vs phenolic for civi model), new R1 Concepts plated-drilled-slotted rotors for some nice show (I'm fully aware they don't have any effect on braking performance), and some ATE pads. I hadn't realized it before hand, but all the parts are made by ATE for Ford, so the whole setup is an ATE setup except the rotors. To hook them up to the existing brake lines, I used new front brake hoses for an 86 Crown Vic (had to do a little grinding on the caliper end), and changed the banjo bolt to a metric one for the calipers. So all I had to do for brake lines, was re-bend the ends of mine to a different location a hook the hoses up. Well, on with the pics.
You still utilizing the emergency brakes? If so how did you go about mating that up with the rest of the car?~David~
ahh awesome. I was just curious because that was the only part of the conversion that was never really clear.~David~
you use the later style parking brake cables to the rear, and couple it to the original cable from the pedal. One is a bit long, so it ends up getting cut down and looped over with cable clamps, and a turnbuckle installed to get the proper adjustment. There may be a better way, but thats how mine is hooked up. It works. if the whole original pedal setup is going in the bin, then you're pretty well free to do whatever you'd like.
Looks good. How do you like the ATE pads?86 Lincoln Town Car (Galactica).
nice work blaze, im interested to see this hand brake setup you speak of
Originally posted by marquisman View Postnice work blaze, im interested to see this hand brake setup you speak of
I've often thought a handbrake would be a nice improvement over the unreliable parking brake pedal arrangement. It should be very easy to do if you put it over to the left of the seat like on an old Ferrari or something. Putting it in the middle, I would think, would be a good bit more involved.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostMake that two of us!
It should be very easy to do if you put it over to the left of the seat like on an old Ferrari or something.) I like my bench seats too much.
Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
