There are 3 of the little rubber disc-like bushings in each motor, right?
Windows not rolling up, but you can hear the gear turn?
This is a sticky topic.
yes. personally I replace them with ball bearings... but that's because I've had them deform on me in the august heat here in Texas and stop working.
Would the bushings going out cause the window to work its way down? two of my 94 GMs windows are doing this.
Tim84 Lincoln Town car signature, R.I.P
85 Ford LTD Crown Victoria 2 door performance project
89 Lincoln town car: RIP
89 Crown Victoria LX 2002 USACi sound quality world champion RIP
1990 Mercury Grand Marquis LS
1994 Mercury Grand Marquis (sold)
2004 Mercury Marauder. owned for a week then got screwed by the dealer
Originally posted by over2tonsofFun View PostWould the bushings going out cause the window to work its way down? two of my 94 GMs windows are doing this.
Tim
the video scott posted is greatsigpic
you got that apart and back together pretty quick. it's almost like you've done it before lolsigpic
You think that might be the case? I'm not so sure lol. I don't think he knows a lot about these cars at all.Originally posted by gadget73There is nothing more permanent than a temporary fix.
:lol:
took my driver door apart... found that previos owner drilled out the rivets connecting the window arm to the door... found that they put it all back in backwards because window motor was on backside of door as opposed to the speaker side... the arm stuff wasnt even bolted to door and just thumping around in the door when i made turns...i unbolted the motor and checked the bushings since it wobbled... they were solid plastic type bushings and flat spotted on one end and round on the other... i am gonna be swapping the bushings now as soon as i make it to parts store... bigger challenge is the arm connecting the motor to window... trying to keep that under enough pressure to allow me to rebolt it is the challenge... i think i have that part solved... just need to get me some bolts and stuff to get it all reattached ... now i see why some species eat their young... some people need to be shot for attempting to repair stuff only to make things worseLast edited by 87_crown_vic; 04-06-2011, 07:37 PM.
ok... messed with fiances 1990 Grand Marq driver door motor... it is a lil different... instead of phillips screw holding cover on the motor it is a torx... and the middle gear you have to take out is held on with a C clip on the center shaft to hold it all together... the bushings in it are shot... literally in pieces looking like a crumbled yellow eraser in the motor
hence the reason many replace them with bearings or nuts. Steel FTW!
