As you all know i am making a " 79 clone ", so i am looking for a 79 steering wheel, plastic one thats in good shape, any way i was just wondering if it is on a splined coloum? and if my 84 would have the splined coloum or the newer style? and if mine has the newer style how much work would it take to switch the shaft?
79 steering wheel question
Originally posted by Dave84 View PostAs you all know i am making a " 79 clone ", so i am looking for a 79 steering wheel, plastic one thats in good shape, any way i was just wondering if it is on a splined coloum? and if my 84 would have the splined coloum or the newer style? and if mine has the newer style how much work would it take to switch the shaft?
Guys in the know - is it hard to install the horn-on-the-turn-signal-switch thing on a later car? Is the switch a bolt-on? Would I need anything other than just the switch and a few wiring connectors?2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostHey, if you come up with an extra good splined wheel, let me know. I sometimes get annoyed with my fingers getting pinched every time I turn a corner. Personally, I'd probably dispense with the early splined wheel in a conversion just because the later non-splined wheels are so much easier to come by.
Guys in the know - is it hard to install the horn-on-the-turn-signal-switch thing on a later car? Is the switch a bolt-on? Would I need anything other than just the switch and a few wiring connectors?86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostMultifunction switch bolts up and plugs in the same, should just be a matter of moving wires from the center pad to the stalk switch. I have a 1984 switch in my car, 84 has the stalk horn where my 86 has the wheel center horn. I dispensed with the 84's lever so it wouldn't push in, but the electrical part is still there. You do loose the flash to pass function from the newer MF switch, but no great loss there.2012 Mazda5 Touring | Finally working on the LTD again!
