Hey guys I have an 87 crown vic and wanted to know how to install a tach. which wire wire and so on thanks, thinking about installing on sterring colum
How to install tach on 5.0 efi
You'd get the signal from the - side of the coil. I forget which color wire, but its not the red/green one. Its the other wire.
and86 Lincoln Town Car (Galactica).
it should be (on my sunpro tach anyways...): red-power, black-ground, white- switched 12v+ source, and the green-coil signal wire, tapped into the negative side
'80 Town Coupé
