Removing Speedo?
    Removing Speedo?
    i kant for the life of me get the damb thing out it wiggles around but wont pull dat far out...help me!
    squeeze the end of the speedo cable and pull it out. youll see theres gripps there.
    '95 Ford Bronco XL -
    sigpic :rebel:
      Cant get your speedo off? Dude, that is way to much information! Not to mention a very bad mental image.
      Seriously though, the speedometer cable is probably holding it like boxman said.
      Axle codes
      Open/Lock/Ratio #
      G / H / 2.26
      B / C / 2.47
      8 / M / 2.73
      7 / - / 3.07
      Y / Z / 3.08
      4 / D / 3.42
      F / R / 3.45
      5 / E / 3.27
      6 / W / 3.73
      2 / K / 3.55
      A / - / 3.63
      J / - / 3.85
        I personally think it's a trap. The car is expecting you to remove the speedo....I saw this happen once on Oprah...
          can someone tell me where exactly the Speedometer Driven gear is?
          I couldn't figure out where mine was...I'm an idiot...I've had the right speedo gear for months and havent gotten it in.
            It's on the driver's side of the tailhousing...pretty obvious, I thought...but maybe not.
              one bolt that holds the cable in the transmission....pop it out and have at it
              Addicted to 86-87 Panthers
