The shift indicator on the 1987 Grand Marquis has been misaligned for years. Today it's on P and won't move. I've seen some threads about collars, cables, and zip ties, but not enough pictures or diagrams to understand the problem, or especially, a solution.
shift indicator - 1987 mgm
Originally posted by jim View PostThe shift indicator on the 1987 Grand Marquis has been misaligned for years. Today it's on P and won't move. I've seen some threads about collars, cables, and zip ties, but not enough pictures or diagrams to understand the problem, or especially, a solution.
Sorry, have no pics to show ya, but when you pull the covers off your steering column all will make sense. Just follow the small cable sheathing (white in color) coming down from the indicator and you'll figure it out in no time.The ones who accomplish true greatness, are the foolish who keep pressing onward.
If it doesn't move at all, check to see if the arm hasn't broken off. Usually when the clamp breaks, the needle moves but doesn't land on the right gear. Once you pull the covers off you'll see the bits in question.86 Lincoln Town Car (Galactica).
Sorry to pull up this old thread, however:
How do I get to the bolt that holds the lever arm to the shifter shaft? I already removed the wiper arm connector and tried to take off the fuse box plus the panel it sits on. No luck. Both, the lever plus the bracket are broken of. I believe I can fix both parts once I can unbolt the lever but cant seem to get to it.Regards, Alex
If removing panels won't give enough access, pull the shift cable collar off and just drop the column. Should be 2 nuts underneath above the brake pedal area and the whole thing will just drop to the seat.86 Lincoln Town Car (Galactica).
No special alignment involved, just push it back up until the holes line up.
The collar for the shift indicator is a plastic loop. Its got one screw that you remove and then just pull it off. Assuming it hasn't already broken into several pieces, in that case you can skip removing the screw.86 Lincoln Town Car (Galactica).
oh, no need to remove the shift shaft, once the collar is out the whole thing will just drop down without any fuss. Be careful lowering it in case there is a wire getting stuck somewhere but it should just lay down on the seat.86 Lincoln Town Car (Galactica).
Sorry to hijack this thread...
Just finished working on the shift indicator.
Thanks for the advice on the steering column, that ultimately helped. I unbolted the top two nuts and loosened the lower twos. The column dropped far enough to reach into the dash and get to the bolt on the shifting rod.
I unbolted the remains of the black lever and pulled the other part off of the little line that goes to the indicator itself. Tryed to glue the parts together with superglue, didnīt stick. I belive the material is ABS or ABS-PC which canīt be bonded with superglue. So I used some regular universal glue. Since I didnīt want to wait the 20 min they recommend before putting both parts together (yes, I am impatient!) I wrapped some tape around the pieces to keep them from separating when I went on messing with them.
I carefully attached the lever back on the shifting rod, fixed the thing with two smaller zipties and finally bolted the part on. Now the glue can take all time it needs to cure and hopefully the lever wonīt fall apart again.
Then I took care of the collar in the way it has been described here various times. I skipped the glueing this time and simply ziptied the hell out of it. Put that little loop I had taken that one off before back on the lever. Moved the collar around until I was ok with the indicator in the dial. Not 100% accurate in all gears (ok in R and O/D), but ok for me and definately better than before. Sorry, no pics, but yall know how it looks under there anyways.
Bolted the steering column back into place, reattached the panels, et voila, a working shift indicator!
It looks more accurate from the angle I look at it when I sit in the car.Regards, Alex
The plastics on these old cars are just disintegrating. I have yet to see that piece broken. I am well away of the white collar breaking though.~David~
I broke one once when trying to unhook the cable to pull the cluster. I think Scott made a new one out of a piece of scrap aluminum bent into the right shape. I don't recall if that was on Tom's car or Donald's.
but either way, the plastic was not meant to last 30+ years.86 Lincoln Town Car (Galactica).
