92 GM Weather tech cargo trunk liner fit a box 91 trunk
    Does anyone know if the trunk dimensions
    On a 92 sedan are close in size to the 91 GM sedan?
    This would be the floor area itself and not the sides or front.
    I came up with
    44 X 28 1/2 inches on the box.
    Thank you
    Mike
    90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
    90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
    91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
    70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
    my 93 (would be the same as a 92) is 44x28.5... so yes... close enough.
      THANK YOU Sly.
