I had decided the other day to throw in the silver Grand Marquis speedometer I had. The reason for this was because I noticed the odometer was not working on the 140mph speedo currently in there. Well, everything worked on the Merk cluster, except for the speedometer. And stupid me, I put the dash back together rather than waiting to see if it worked 100%.
Tonight, I disassembled both clusters and took the best of both and combined them. For starters, I took the odometer and the mileage indicator, and installed them into the 140mph cluster. I then installed that into the main housing of the cluster. I used the Merk housing as the printed circuit was in better shape. I also threw in the new bulbs(not led or blue unfortunately
)from the 140mph cluster. Tomorrow I'll install it, and hopefully it will work ok. I also removed the airbag and seatbelt lights from the cluster.
