How much do the coupes wieght
    yup, or when we had emissions testing they weighed my car.
    -Phil
      Originally posted by MattsGrandMarquis View Post
      where do find the actual weight then
      The Encyclopedia of American Cars has stats for all Panthers up to 2002. US prices when new, trim levels, curb weights, engine choices, hp ratings and production numbers.
      '79 Continental Town Car
      '90 Crown Victoria LTD
      '94 Crown Victoria
        find a coal breaker, get on thew scale, then go into the breaker, fill the trunk with rice coal, then come see me and we will read the weight slip after we put the coal in my bin
          Try to find the link (posted here in a few places) to Motorcraft.com where you can look up a few original specs by VIN number. My '81 2-door was evidently 3460 pounds new.
          Got this reply to my inquiry on what happened to their little online lookup tool:
          Hello,
          The Motorcraft Technical Resource Access Page can be found by selecting Pro Center > Motorcraft Technical Resources.
          Everything you need to know about Ford, Lincoln and Mercury vehicles - inside and out.
          It’s all here: TSBs, workshop manuals, wiring diagrams, diagnostics and more. Browse the site and purchase a
          subscription; with regular and reliable updates direct from Ford Motor Company, this site is the only technical
          information resource you need.
          Please use the contact us at the bottom of the Motorcraft Technical Access Page should you require assistance with the
          site.
          http://www.motorcraftservice.com/vdi...ageid=feedback
          Thank you for using FordParts.com!
          Sincerely,
          FordParts.com
          Website Development Team
          www.fordparts.com
            Or a landfill, scrapyard...etc...
            I took my wagon across some scales.... just shy of 4500lbs.
              I still haven't figured out why your wagon should weigh 500 pounds more than mine ....
                Coupes are less than 100lbs lighter than sedans, wagons 2-300lbs heavier than sedans, generally speaking. This is according to a big ford encyclopedia I have. It has stats for every year.
                  Can anyone explain to me what the weight figures on the jamb tag mean?
                    gross vehicle weight rating i think. how much weight that axle can support.
                      So none tell the weight? I think there are three readings...what the hell are their purpose?
                        The gvw is the weight of the vehicle plus its max load it is rated for, I believe.
                        So say if a car is 4000lbs and it can carry 1000lbs the gvw would be 5000lbs.
                        Correct me if im wrong.
                        '90 LX 5.0 mustang
                        Big plans
                          I am going to be weighing my two door in the spring, right after I get some of the junk out of it.
                            This is correct.
                              My 85 2 door fully loaded weighs in at 3892 with 75 pounds of subs in the back of it at the local scrap yard. Made my dad get out when we weighed it, and I subtracted my weight from the total.
                              85' Crown Vic 2dr. Small tire stock block grudge car.
                              09’ CTS-V family car making over 700whp with ease.
                              79’ f350 427 ls7 swapped with th400. Prerunner setup
                              64’ c30 dually. Slammed and turbo 5.3 with 4l80e
                                Cool. Probably around what my car weighs..I have about 75 pounds of sound deadening.
