Does anyone know where to get a whole new engine bay harness that plugs in from the fire wall for a 84 grand marquis??
New harness?
junk yard. There's no aftermarket support for wiring on panthers.
New ignition system or not, your best timing will depend on a lot of things, including the plugs you run, the octane rating of your fuel, and how hot your engine runs. Set it to 10* or so and keep cranking it up until you hear detonation or feel power loss.
To get a signature, click "settings" in the top right corner of the page, and in the page that appears you'll find "edit signature" under the My Settings section on the left side.
Okay so I ran the accel ignition module and it ran awesome! But them it started missing while I was driving and taking forever to crank just to see what would happen I went back to the stock module and it ran fine but less pep like with the module. Is that suppose to happen? Or was the accel module to much for the computer? Is there a aftermarket ECM that can accept the module that's high performance?sigpic
Its an '84. That engine won't accept high performance. Its right down there with the weakest motors Ford ever made, and its not because of the computer. The fuel injection system it uses, the cam, and the cylinder heads are most of the issue. Also, these have a lousy timing chain design that can let the cam skip and bend valves.
Truth be told, the best thing you can do with a CFI car is to do the vacuum lines, timing chain, tune it up, put dual exhaust on it, and enjoy the fuel economy. Its never going to be fast unless you push it off a cliff or change the engine and it's injection system out to something better. When they're running right, CFI is smooth as glass and cheap on fuel but thats really all you can honestly say for it.86 Lincoln Town Car (Galactica).
That's just it.... I had the heads and Intake ported out I put a double rolling timing chain in it with a torque cam. I also have shorts and straight pipe exhaust. The SOB moves but I tried the accel module out and it worked for a little then it started missing.sigpic
its probably running too lean. The CFI system does not take well to modifications. Someone on here did mess with one, going with larger injectors and changing the pressure regulator settings but I can't quite recall who it was.86 Lincoln Town Car (Galactica).
