Have a look at the freeze plugs on the side of the block and make sure they aren't seeping. If they are, get it dealt with ASAP before one blows on you. They usually build up a bunch of cruft and corrosion shit when they leak.
power steering pump -- '91 GM
Might just need to snug the clamp down a little. There might be some crunk between the radiator and the hose, and its seeping around that a little.86 Lincoln Town Car (Galactica).
I should try that. I have a new PS Pump... but my dad broke the pully tool taking it off the other vic.1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
Supermotors
:bump:
I replaced the ps pump on the '91 GM today, but the new pump is just as noisy as the old one. I thought I did the process right when filling the pump for the first time. Nothing appears to be leaking.
Would air in the system cause the noise? What can be done to remove the air (anything without buying the specialty tool?)? Could any damage be done if the car is driven this way?
there is no specialty tool monty......just drive it for a few days, if it dont shut up, get a bottle of lucas ps treatment and suck ps fluid out with a dollar store turkey baster and add half the bottle of the lucas.......quietness everytime
keep driving lol........if it dont shut up, take the ps pump back and get a new one.......hope it isnt from autozone
you need to bleed the air out of the system.
support front end on jack stands, with the engine off, turn steering wheel back and forth slowly. you will see the air bubbles coming out of the resivoir. when you dont see anymore bubbles you're done.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
