Washers pump won't turn off
    My washer pump won't shut off after I use it. Turned off the ignition to stop it but it re-starts when turning ignition back on. Replaced the multifunction switch and still does it. Removed wire from pump and it's getting 12v continuously. Does this mean there's a short between the pump and multifunction switch?
    Year & model? Washer pump relay might be broken and stuck on.
    Mods might want to move this thread to a more appropriate section.
    2005 Volvo V70 Bi-Fuel
      Once we find out what year/model it is, we can move it to the right section.
