Since there is becoming a bit of info here I decided to move it to a better location.
{Engine} Just Spent $530
Is it worth the extra cost to go with aluminum rockers (over iron/steel/whatever) or is that just for the bling factor?2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by FreshmeatIs it worth the extra cost to go with aluminum rockers (over iron/steel/whatever) or is that just for the bling factor?
Blaze, i hope for that price those rockers are new. I paid $150 for a set of used 1.72 Scorpions They run about $225 new (The Scorpions are regarded as being as good if not better than the Crane Gold rockers) Those Ford rockers are made by Crane.http://secondhandracing.com/Home.aspx
Originally posted by Blaze86VicYes the rockers, springs, and all gasket are brand new, not used.
I need to replace the valve springs in my heads. have unknown milage on them. i get valve float above 5500RPM. have 2 sets of dual springs laying around. but not sure if i want to mess with them. The ehads im going to get come with 1.47" dual springs that handle .600" of lift.http://secondhandracing.com/Home.aspx
I'm aiming for ~5,500 RPM redline so I can get good, low power. Anything above that on a 4,000lb station wagon is plain greedy. I do plan to upgrade my springs, though, because these on the engine are at 100,000ish miles and I don't trust worn springs. I'll swap when I do the roller rockers... what valve covers should I run with 1.7s?2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by FreshmeatI'm aiming for ~5,500 RPM redline so I can get good, low power. Anything above that on a 4,000lb station wagon is plain greedy. I do plan to upgrade my springs, though, because these on the engine are at 100,000ish miles and I don't trust worn springs. I'll swap when I do the roller rockers... what valve covers should I run with 1.7s?http://secondhandracing.com/Home.aspx
Originally posted by N AOriginally posted by N AHave you tried the '87-'93 HO upper intake? Wouldn't it flow more air than the '94-'95 HO upper?
I didn't know they were different parts. I'm using a "worked" Explorer intake in the 5.0L CV/GM/TC location. :evil: I hope people fall for it if I pop the hood.
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
Originally posted by Blaze86VicNote the curve in it. I would lose the curve if I went old school. Also, that would require me to do a crap load more work to un-convert the engine bay. Eventualy I will be going to the Cobra version of my intake
