Does anybody know if marauder lowering springs will fit an '02 panther?
Spring question
And unfortunately all the testing is on box vics... But the results should be quite similar. I'd think that the newer cars would sit a bit lower due to the added wieght on the newer panthers.Builder/Owner of Badass Panther Wagons
maybe stock box springs will give his panther what hes looking for?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
wouldnt they lower it a little???Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by mrltd View PostAnd unfortunately all the testing is on box vics... But the results should be quite similar. I'd think that the newer cars would sit a bit lower due to the added wieght on the newer panthers.http://secondhandracing.com/Home.aspx
how much does handling improve going that high up in spring rates??Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I guess they would be a little soft...
could the performance springs make an aero or whale too low?
Or would the reduced downward travel of the suspention (untill contact with the rubber bumps) be made up for by the extra stiffness of the spring? What about shock travel, or would the same effect apply to shocks too? I guess it would...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Depends on the length you start with, its possible that what drops a box 1" will drop an aero even more. I do know that stock whale springs are way frickin tall in a box. Not sure if you ever saw my car when I had them, but for a while I ran 98 Grand Marq spings. 700 in/lb, but way too tall. It rode like crap and looked stupid. Now I'm using the heavy duty box sedan coils and its too low.86 Lincoln Town Car (Galactica).
