i need to know if the grille from the "S" crown vics is the same size and mounts the same to the car as the usual grille. i'm talking the grille that has light housings in it. if they are a match fit and mount wise, i'm going to try to procure one for my project with christine. ithe only chrome on the grille will be the housings and the surround.
this is the grille i'm referring too. somebody before said the grille was wider than the other one. the only problem i see with that is that ford would of had to make a different hood for the s-models. thats alot of money for ford just because of a different header panel
edited to add pic and new info
