So if you dont know I have a amp in the trunk that ran to all my speakers and never got feedback before tonight. So I have had my front components disconnected until tonight and been playing music out of rear speakers never got feed back tonight I put door panels on and got horrendis feed back thru speakers...what could it be?
So I went to finaly put my door panels on and I get horrendis feedback!
It could be a lot of things...
Is this the first time you have had the front speakers hooked up to the amp? If not, did you add to/change the wiring to the other speakers or amp, or do anything electrical while they were disconnected?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
odd... try unhooking the front speakers again and see if it goes away... that may rule out something else going wrong at the same time by coincidence, like a noise suppressor under the hood or something. I'd have though that kind of noise is picked up in the pre-amp wiring and would have made the rear speakers noisy too. Could you have piched a wire, or put the speaker back with a terminal against the metal door panel?
I'm no audio guru though so don't, eemmmm, something about a grain of salt.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Just for the record..and It might help. In my tercel...if the battery cable is unhooked with the engine running, I get insane amounts of feedback through my speakers as well. And yes, the more rpms, the louder it gets. (odd thing is, I dont have the same problem with the LTD)
So...maybe you knocked a ground wire loose? Losing a ground causes all kinds of crazy things to happen.
make sure the speaker terminals aren't touching the door skin. I had the dashtop off Scott's car and its doing this stuff now. Pretty sure I got one of the speaker terminals touching the metal in the dashboard.86 Lincoln Town Car (Galactica).
the filter cap on the coil could also be dead. If that thing dies... you'll get all kinds of high pitched noise on the speakers.
Originally posted by 83countrysquire View Posthigh pitch whinnig that goes with rpms of the car...foot on gas whinnin gets higher and louder89 townie, mild exhuast up grades, soon to have loud ass stereo....
