According to the garage, my E-brake connector has a little bit of crap on it that prevents it from grounding when pressed, which prevents my E-brake light from coming on, causing me to fail inspection.
So I have to sand this part:
Is there a way to get to it without removing my kick panel? I can see it about 5 or 6 inches away through about a 2 or 3 inch gap between the kick panel and the A-column. It seems to be secured with a single screw and connected to the wiring harness
