PDA
View Full Version : 1985 CV {351 street rod } *DUW* *UPDATED* page 2
DuceAnAHalf
12-13-2005, 05:34 PM
just thought id put a group of pictures together.
1985 Ford LTD Crown Victoria (according to Ford it is a LX, but it is not badged, and it only has/d cruise as an option.)
I bought the car in Spring of 2000. the original motor blew in december of 2000. Over the next 18 months the motor was replaced with another lo-po 5.0, but had a Weiand Action-Plus intake and a Holley 600 vac. carb installed. The motor was replaced with a used oil-pump. after about 6 months of driving it, I parked it. over the next 2.5 years i got almost nothign done to the car itself, about the last 6 months of that time i built the engine and assembled parts. over the next few months I installed the motor, rebuilt the rear end with a 3.55 and a trac-lok, aklso installed rear disc. I stripped all the excessive weight out of the car. I re-tagged the car again in late October of 2005, on a Thursday. that saturday i drove it 40 miles each way to the Drag strip and ran a 15.98 @90 with no traction and a crappy hal-blow AOD
If you would like any information, or a closer look at anything PM me or respond in this thread.
exterior
The first two pictures are of the current front end. it is the 79 grill and clear corners with the hood ornament. Also have the 79 tail lights.
http://www.supermotors.org/getfile/287735/original/120_2069.JPG
http://www.supermotors.org/getfile/287736/original/120_2071.JPG
http://www.supermotors.org/getfile/267721/original/116_1634.JPG
http://www.supermotors.org/getfile/267738/original/116_1641.JPG
http://www.supermotors.org/getfile/258588/original/111_1122.JPG
about time i do an update.
added a 2.5" cowl, painted the hood black, and then painted the car in desert camo.
http://www.supermotors.net/getfile/621989/fullsize/img_0707.jpg
http://www.supermotors.net/getfile/621994/fullsize/img_0708.jpg
DuceAnAHalf
12-13-2005, 05:37 PM
interior. it is very plain. no sound deadening, no back seat, no heat or air or even a fan. behind the dash there is only the chassis and engine wiring. No factory computer
http://www.supermotors.org/getfile/204587/original/106_0662.JPG
New steering wheel. Grant Challenger GT.
http://www.supermotors.org/getfile/287052/original/120_2064.JPG
Steering Wheel quick release hub.
http://www.supermotors.org/getfile/287053/original/120_2065.JPG
Drove the car to work today. Had the quick release adapter TIG'd onto the shaft.
Yes the wheel sits centered, the wheels are turned in these pics
http://www.supermotors.org/getfile/287725/original/120_2066.JPG
http://www.supermotors.org/getfile/287726/original/120_2067.JPG
http://www.supermotors.org/getfile/287727/original/120_2068.JPG
re did the headliner with a raised LTD script.
http://www.supermotors.net/getfile/308110/fullsize/122_2286.jpg
guage set up
http://www.supermotors.net/getfile/453974/fullsize/img_2621.jpg
here is the kirkey mounted.
http://www.supermotors.net/getfile/431641/fullsize/img_2472.jpg
http://www.supermotors.net/getfile/431642/fullsize/img_2473.jpg
removed the rear seat and rear deck, replaced them with .032" aluminum
http://www.supermotors.net/getfile/431648/fullsize/img_2468.jpg
DuceAnAHalf
12-13-2005, 05:41 PM
engine
http://www.supermotors.org/getfile/158619/original/105_0556.JPG
http://www.supermotors.org/getfile/158111/original/intake.jpg
http://www.supermotors.org/getfile/188836/original/106_0604a.jpg
http://www.supermotors.org/getfile/273000/original/118_1861.JPG
http://www.supermotors.org/getfile/273001/original/118_1862.JPG
http://www.supermotors.org/getfile/273003/original/118_1865.JPG
http://www.supermotors.org/getfile/256447/original/110_1091.JPG
http://www.supermotors.org/getfile/256645/original/110_1096.JPG
http://www.supermotors.org/getfile/244949/original/110_1038.JPG
http://www.supermotors.org/getfile/235930/original/110_1012.JPG
painted the motor in Vietnam era tiger stripes.
http://www.supermotors.net/getfile/620268/fullsize/img_0700.jpg
http://www.supermotors.net/getfile/620269/fullsize/img_0701.jpg
http://www.supermotors.net/getfile/620270/fullsize/img_0702.jpg
DuceAnAHalf
12-13-2005, 05:45 PM
Fuel system
http://www.supermotors.org/getfile/169328/original/105_0594.JPG
http://www.supermotors.org/getfile/169329/original/105_0595.JPG
http://www.supermotors.org/getfile/251139/original/110_1066.JPG
http://www.supermotors.org/getfile/251141/original/110_1068.JPG
http://www.supermotors.org/getfile/222223/original/109_0932.JPG
http://www.supermotors.org/getfile/222225/original/109_0934.JPG
DuceAnAHalf
12-13-2005, 05:48 PM
suspension.
http://www.supermotors.org/getfile/168057/original/105_0586.JPG
http://www.supermotors.org/getfile/168059/original/105_0587.JPG
DuceAnAHalf
12-13-2005, 05:49 PM
exhaust
http://www.supermotors.org/getfile/158110/original/headers.jpg
http://www.supermotors.org/getfile/265036/original/112_1216.JPG
http://www.supermotors.org/getfile/265039/original/113_1357.JPG
mrltd
12-13-2005, 06:05 PM
Whatcha doing with the t-bird rear cover?
I'd think that the way the arms are boxed will cause the metal shells to rip out of the rest of the arm. I'd weld the shells to the arm or weld 'em up all the way.
DuceAnAHalf
12-13-2005, 06:07 PM
the T-bird rear cover was going to be the mount for a torque-arm and Watts. but i think that im going to run a Three link and a watts.
mrltd
12-13-2005, 06:12 PM
Sweet, that's what I figured. I gotta decide on the rear setup for the wagon.
Ever look at an aerostar 3 link? Might be an easy thing to modify for a panther.
DuceAnAHalf
12-13-2005, 06:15 PM
Ill just build a third link, using some 3/4" chrom-moly rod ends and use a threaded tube to adjust the pinion angle.
mrltd
12-13-2005, 06:18 PM
Easy enough also.
85crownHPP
12-13-2005, 06:36 PM
I see you cleaned up under the hood! looks nice whithout all the uneeded crap in there :cool:
zwack88
12-13-2005, 07:21 PM
Looks good! If you don't mind me asking, about how much have you invested into this beast? :drool:
DuceAnAHalf
12-13-2005, 07:59 PM
Car $700
AOD was rebuilt before i stopped driving it $700
long block $500
intake $240
headers $90
oil pan and pick up $190
oil pan gasket $35
roller rockers $150
distrubtor $240
MSD 6AL $210
carb gift but is $320
new dampner, water pump, power steering pump, belt $100 or so
Radiator $150
Oil filter set up $75
valve covers $70
fuel pump about $100
FPR $80
fuel cell about $150
Shifter and cable about $130
guages $90
Front shocks $100
Front springs about $10
rear shocks $26
rear springs free out of my 97
wheels and tires $400
rear brakes $100
trac-lok and 3.55s $12
battery relocation kit $40
Fuel lines and fittings about $150
thats about all i can think of, there is a bunch of other little stuff so add about $200 more
that comes up to $52xx i was guessing that it was about $5000
DuceAnAHalf
12-15-2005, 06:59 PM
http://www.supermotors.org/getfile/273440/original/118_1883.JPG
Paul_
12-16-2005, 02:16 AM
:drool: :drool: :drool: :drool: :drool:
BlackHawkA4
12-18-2005, 05:14 PM
O... MY... GOD... :woot: YES!
bruno
12-18-2005, 05:42 PM
you son of a bitch, I want this :drool:
89LincolnTWNcar
01-22-2006, 07:40 PM
Any dyno numbers or track times yet?
DuceAnAHalf
01-30-2006, 05:30 PM
Updated the interior section.
No times yet. Once the tranny goes in i will get top at least the 1/8th mile and get some new times with the drag radials.
Transmission.
Performance Automatic Competition C-4 rated to 750HP.
http://www.supermotors.org/getfile/285458/original/120_2002.JPG
mrltd
01-30-2006, 09:20 PM
eeew...PA. Sorry...
I bought one of thier C4's...I put the stock 300K mile one back in. It leaked less and actually shifted. Saved 750 bucks
DuceAnAHalf
02-01-2006, 08:03 PM
Interior and exterior updated.
zwack88
02-01-2006, 08:43 PM
Looks great! I have really enjoyed watching your build up Duce! ;) I like the rear tails with the black border and the classic LTD in the lights. Are you going to do any black accents with the new front? I really liked the blacked out front before.
DuceAnAHalf
02-01-2006, 09:31 PM
I might black out some of the center of the grill. If i can find another early grill i might paint it black but i dont want to mess up my 79 grill and not be able to find another.
Blaze86Vic
02-20-2006, 09:59 PM
You can buy the grill on ebay brand new.
DuceAnAHalf
02-21-2006, 08:15 PM
yeah, but i dont do EBAY
Blaze86Vic
02-21-2006, 09:56 PM
OOHHH MR I DON'T DO EBAY! lol, I feel ya man, I'm about to call it quits as well. But first one more screw me over to go please...
sniper308
07-06-2006, 12:30 AM
:cop: C4's sound like a Bomb.????
ATT, SNIPER 308.FAREWELL BLACKHAWK-P74 INTERCEPTOR I WILL NEVER FORGET YOU MANG.
DuceAnAHalf
07-06-2006, 12:44 AM
Composistion 4 also known as "C4" is an explosive. A C4 is a three speed non-overdrive transmission, first built in the early 1960's
DuceAnAHalf
05-04-2007, 08:36 PM
Figured it was about time to update this.
i painted the hood and the scoop flat black, i also put the black front end back on.
I also replaced the original chromed steel bumper with an aluminum bumper off of an 85 wagon.
http://www.supermotors.net/getfile/503483/fullsize/img_0337.jpg
http://www.supermotors.net/getfile/503345/fullsize/img_0333.jpg
http://www.supermotors.net/getfile/503485/fullsize/img_0339.jpg
I replaced the E7 heads with a set of E8JE heads (early marine GT-40 heads)
when i did this i cleaned up the intake casting a little.
next day i ran a 13.37 @99 with a passenger and a glitchy nitrous system.
http://www.supermotors.net/getfile/477642/fullsize/img_0122.jpg
I added an additional cooling fan and a second tranny cooler,
i also boxed in the radiator to help with cooling (it does not get above 190degrees anymore).
http://www.supermotors.net/getfile/437155/fullsize/img_2598.jpg
http://www.supermotors.net/getfile/431640/fullsize/img_2491.jpg
http://www.supermotors.net/getfile/431639/fullsize/img_2469.jpg
http://www.supermotors.net/getfile/431637/fullsize/img_2462.jpg
http://www.supermotors.net/getfile/479095/fullsize/img_0128.jpg
i installed the Kirkey drivers seat, i now have a
passenger side seat also, just have not replaced it yet.
I have removed the back seat and rear deck, both have been replaced with .032" aluminum.
http://www.supermotors.net/getfile/431645/fullsize/img_2494.jpg
I have also recovered the headliner, it now has a raised "LTD" logo in it.
http://www.supermotors.net/getfile/305124/fullsize/122_2237.jpg
Front suspension now has the original springs back in it,
along with a set of Competition Engineering 90/10 shocks,
also the front sway bar has been removed. best 60' time is a 1.92.
here are my two 13 second timeslips.
http://www.supermotors.net/getfile/497384/original/img_0185.jpg
here is my best run.
http://www.supermotors.net/getfile/450901/fullsize/whitecrownvicvsblueacura.wmv
here is the best dyno graph from the old heads. this was a nitrous pull,
the nitrous plate had the wrong fuel hole in it so it ran pig rich (well richer than 10.1)
the pull is from 3000 rpm to 5,000rpm, with valve float starting at around 4500.
http://www.supermotors.net/getfile/433071/fullsize/dyno-run-2.jpg
it put down 213/280 on motor alone and the "125" shot only increased it to 270/308,
it should have been more like 330/420. that is through an automatic with a non-lock up converter
so there is a good 25% driveline loss
Grand Marquis GT
05-05-2007, 02:55 AM
Lookin good, mang!
DuceAnAHalf
04-18-2008, 10:07 PM
updated the first page, but apparently i already added some of them. oh well.
so here is a track video. 13.37 @99
http://www.supermotors.net/getfile/450901/fst/450901.jpg (http://www.supermotors.net/vehicles/registry/media/450901)
DuceAnAHalf
08-25-2008, 02:19 AM
Got the exterior painted. the desert camoflage paint scheme is inspired from a German Panther tank from WWII, the cross is not a nazi symbol, it was used to identify german vehicles, and is still in use in germany today.
http://www.supermotors.net/getfile/654091/fullsize/img_0749.jpg
http://www.supermotors.net/getfile/654092/fullsize/img_0750.jpg
also in the process of painting the engine components form the Ford blue to a tiger stripe pattern
you can see here that the throttle bracket is tiger stripe also
i have also removed the power steering system
grandpaslincoln
07-19-2014, 03:20 AM
I know I'm digging up bones here, but what belt did you end up going with after you ditched the power steering?
