I'm taking the lighted lock cylinders off of the blue vic and putting 'em on the '91. I have the door panel off and I can't even see the damn thing or how to remove it. Am I just retarded or am I actually missing something?
How in the world do I get the lock cylinders out?
they are held in by retaining clips that are pryed off from the side of the door, you cant miss em...they are jus tabs that you take a screwdriver to.
yeah, it works like an E clip but in a "U" shape. jsut like how the glove boxe latches are help in, but more heavy duty.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Just pull the rod out of the plastic clip on the end of the lock cyl, slide that clip out and it just about falls into your hand. Took me a bit to figure it out the first time I removed one. Its so simple its almost too easy LOL.86 Lincoln Town Car (Galactica).
Mine worked in the Townie with either the interior lights on or the door open. Do your interior lights work? Should be on the same circuit.86 Lincoln Town Car (Galactica).
