My sis is being kind enough to let me swap rear ends with her 94 cop car. The axles should interchange easily if I am correct, but what about the 94's sway bar, can I use it on my 85? Do the control arm bushings need pressed in and out to replace? Is there anything else I need to watch out for? I think it has drums, not disk brakes, but I havent checked yet.
94 and an 85 axle swap
My rod is glowing, my bead is clean, my middle name is acetyleneTags: None
a 94 has rear disc. It also have different brake hose routing, you will have to re-plumb a little if you go with the rear disc.
92+ sway bars use endlinks, you would have to drill the frame to accept the endlinks.
Bushings have to be pressed out.http://secondhandracing.com/Home.aspx
damn, thats what I was afraid of. Does the disk brake rear have the same hose connection above the pumpkin like my 85 does? I'm gonna do some thread searching about rear disk swaps
no it doe snot. you will have to cut and flare lines. on mine i used the 92+ brake lines on the fram, had to cut and flare one line. Lincolnmania can tell you what you need to do it.http://secondhandracing.com/Home.aspx
Whem the cars here I'm gonna look at it, My front parking brake cable is snapped so I dont care about them being functionable on my car, but I need them to work on the 94. Does anyone have pics of the connections of the brake lines and cables?
Why are you swapping the entire rear? It might be easier to just do a gear change on your car rather than ripping 2 apart and having to deal with converting drums to disk and disk to drum. Check the classifieds, I remember mrltd had a few sets of gears and traction lock units for sale cheap.86 Lincoln Town Car (Galactica).
are the pinion shaft flanges the same? I was thinking they are, but then I want to say I remember hearing different.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Well its a 3.27 locker (e code). I would swap the internals but Setting back lash and shimming on the gears seems like a lot more to me. I remeber reading countless articles on how to do it, but I still am sorta nervous about doing all that. I guess it would be easier, and I wouldnt have to mess with the brakes too. I havent looked under it yet too see for myself how difficult it may be.
I'm gonna go ahead and swap out the 3.27 gears and the traclock for the open 2.73's. Seems like the easiest way to go at this point. She needs new rear rotors so when I replace those, i'll rip apart the rear.
You might be better off with a 3.55 and a trac lock. I'd seriously consider rebuilding the traction lock in any case before you install it. $50 kit from Summit. I'm gonna warn you, her car is gonna be a total dog with a 2.73 rear, worse than yours is. 4.6 motors need a higher gear simply because they don't have a ton of low end torque. There is also the fact to consider you're tearing apart 2 rears, requiring shimming and adjustment for 2 vehicles vs just doing one. You also have to replace that crush collar and probably some other stuff I disremember offhand. Also, if you're pulling apart high mileage rears, it would be a good idea to replace the bearings and seals too. Just want to make sure you know what you're in for ahead of time.
And the rotor replacement does not require tearing apart the rear. Just pull the wheels and calipers, and the rotor slides off.86 Lincoln Town Car (Galactica).
Originally posted by gadget73You might be better off with a 3.55 and a trac lock. I'd seriously consider rebuilding the traction lock in any case before you install it. $50 kit from Summit. I'm gonna warn you, her car is gonna be a total dog with a 2.73 rear, worse than yours is. 4.6 motors need a higher gear simply because they don't have a ton of low end torque. There is also the fact to consider you're tearing apart 2 rears, requiring shimming and adjustment for 2 vehicles vs just doing one. You also have to replace that crush collar and probably some other stuff I disremember offhand. Also, if you're pulling apart high mileage rears, it would be a good idea to replace the bearings and seals too. Just want to make sure you know what you're in for ahead of time.
Thanks gadget, I was thinking about it today and decided not to do it. seems like way more work than it its worthand a 3.27 aint that good, and you are right the 94 is slow enough anyway. I'd probably end up replacing all the seals and bearings. I'm gonna be working alot this summer so I can get somethings I really want like 3.73's or 3.90's.
your susposed to check backlash but in my experance if you dont change the carrier as long as the shim between the back of the pinion is the same as the old one your really dont need to re shim everything ive done it several time and had no probs but you should replace the cruch collar and check that the ring and pinion are engaging properly (marking compound) ok now everyone can bitch about how bad this is
