Driver side window problem.
    Hello everyone,
    Have been having trouble with a sticky/lazy switch for the power window. Yesterday my wife couldn't get the window to close, she stopped by a repair shop and got an estimate. $200.00!!! Made me start thinking maybe I should try to fix it myself. I looked at the small panel where the switches are located and thought if I can get that open and maybe replace the switch,it would be fixed. Has anyone had this type of problem before?
    Thanks for any help.
    Year and model of car??? Switch or gear set/motor issue??
      If it's 91 or older it may not be the switch at all, may just need some very inexpensive bushings replaced in the motor. If it's 92 or newer I will not be much help, I believe the window mechanism was redesigned in 92.
      Vic
        Thanks very much for the response. 2005 LS is the model.
          probably the little white plastic bushings in the motor. open up the window motor and 3 bushing/pins are in there. if they are broken replace them and the window will work smoothly again. This happened on my 95 Crown Vic. They are $5 online.
            On an 05 I would guess a bad motor or regulator. I don't think it would be the plastic bushings that are such a curse with older models.
            I may be wrong but I think the motors were different on those and the plastic bushing were no longer a problem.
            I would take the door panel off, get in there and see what needs to be done.
            It's easy on those whales.
              When you hit the switch, does the motor turn? Or at least sound like turning, but the window is bearly moving? Does it almost sound like the motor skipping??
              08 Lincoln Navigator L - 233k
              03 Mercury Marauder- 63k
