Anyone know where I can find a new or very good used dome light lens for a box Crown Vic ('86)??? They are not an item that you can get from a parts store, and I know this lens was used on many years production of FoMoCo vehicles from the mid-'80s through the mid-'90s. The cars I've seen in the local pull-a-part places have them either missing, cracked or broken. Ideas?
Dome lens needed
If you want a stock white cover order one from LMCTruck.com
Part# 47-4275
http://www.lmctruck.com/icatalog/fd/full.aspx?Page=155
Or a clear one, also from LMCTruck.com (which I have in my 91 MGM, matches the stock light covers on the doors/armrests)
Part# 47-4291
http://www.lmctruck.com/icatalog/fd/full.aspx?Page=75Vic
dammit, "not available at this time". Clear ones can be had tho. Hell of a lot cheaper than the stock lens as well.86 Lincoln Town Car (Galactica).
Oops, I didn't check availability but with this slow backwoods internet at my parents' house it would probably take a few minutes to load the page to find that out.Vic
I've seen them available in the help section of some autopart stores.
I have had the stock one, the "help" part as well as the LMC truck clear one.
The stock one was off white yellow from just being old.
The "help" one was a frosted white color.
The LMC truck one was super clear. It was a very snug fit and am worried about breaking it should i ever have to remove it.
They each provided a different warmth to the interior. I currently run the LMC model and like the ample amount of light that shines through it.Last edited by 87gtVIC; 02-28-2015, 05:08 AM.~David~
I have a fairly good shape stock one, and the light it produces is paltry at best.86 Lincoln Town Car (Galactica).
I bought the clear one (from LMC) after Dave posted about it. It is on my '87 GM and I have copious amount of light coming from it. As Dave points out, however, it IS a tight fit and wouldn't want to test the plastic tabs by removing it!!
Anything that might be fixable with a couple minutes and a file ? If it has casting flash, often just knocking that off will make parts fit nicely.86 Lincoln Town Car (Galactica).
I'd probably recommend anyone purchasing one to test fit and file if necessary. I will not though attempt to remove it to ensure it can be reinstalled easier. I will give it a once over with a file if I happen to replace the dome lamp and removed it without splitting it in two.~David~
I got one of the clear lenses last year and it felt like it was loose if anything, it has been on since installed and I had taken it off a few times with no issues.1989 Country Squire - Twilight Blue, 347 stroker
Hmm, all kinds of differing experience with the fitment.
I believe mine was tighter than stock but not bad enough to make me want to do anything about it. I think some light filing may help but meh it's good enough for me.
I don't think I have removed mine since I put it on 1.5-2 years ago. Like miamibob pointed out, I also got mine after Dave posted it so I can't take any credit for for finding the links I posted.Last edited by VicCrownVic; 02-28-2015, 11:09 PM.Vic
