Hello again
I have some strange things happening on my dashboard and the heater display.
First, the heater display keeps randomly changing from °C to °F and the heat cannot be controlled. I have one setting and that is "hot" all the time unless I shut the heat off. It will display different temperatures though.
Second, the light that let's you know when you have your highbeams on does not always come on. Sometimes it shows up out of nowhere and disappears again. Once I can see it and I flick the highbeams on or off, it does not react to it.
Third, the break light showed up now since two days. It comes on and disappears in a few minutes and you can watch it fade out. Or it stays on all the way. Breaks are OK and fluids too. Safety break is eliminated.
Any ideas?
Thanks
Sent from my SM-G950W using Tapatalk
Any ideas?
Thanks
