Not sure how the 4.6 flexplate is put together, but on some motors the ring gear presses or welds on to the flexplate. It is possible for the ring gear to come off the flexplate on those. Its not common though. Stick a breaker bar on the front of the crank pulley and give it a spin. It should be fairly easy to determine if the crank broke. Honestly, it would be very very unusual to snap one without the crank pulley sitting messed up, or the starter making horrible sounds, or some other visual clue that catastrophe happened. Crankshafts are not easy to snap.
1997 CVPI 4.6 Broken Crank
Define "not rebuildable". Lots of people have rebuilt Modular engines, especially those with performance and racing goals in mind. Timing cover fitment is supposed to be a pain in the butt if head milling is required, though.Chris - A 20th Century Man \m/ ^.^ \m/
Originally posted by bluebeast86 View PostI'm starting to wonder if it was a good deal lol. A couple weeks after I bought that there was a '99 P71 that ran and the tranny was good and was in pretty good shape for $400 on Craigslist, the only thing wrongh with it was bad rearend.
Also, I do not believe the flexplate is broken because it is still in position perfectly like it's supposed to be. If it were broken, would it not be loose?
Originally posted by Grandpaslincoln View PostSince the flexplate is also bolted to the torque converter, and the converter is attached to the transmission, the flexplate will stay in position.1963 Oldsmobile Dynamic 88 Holiday
1964 Chrysler Newport
1986 Ford LTD Crown Victoria LX
1997 Ford Crown Victoria Police Interceptor
take the torque convertor cover off, and see if you can get it to slide towards the transmission, some of them will, if it does slide back then the flex plate is broken for sure. i'v seen that happen. you shouldn't be able to rock or slide the Torque convertor at all, if it seems to move independantly of the engine, then there's your problem. it's not really hard to change one either, a good weekend project. unbolt trans, slide it back enough to get the torque wrench back up there and your set.1996 Grand Marquis White, 288,600 miles as of 4-3-09
4.6L cvpi engine and pcm, Dual Exhaust, Blue Leather Interior, Keyless Entry and Remote Start, DOT Strobes, LED Front Marker Lights, Running 93 Octain Fuel.
Originally posted by eaglegcil View Posttake the torque convertor cover off, and see if you can get it to slide towards the transmission, some of them will, if it does slide back then the flex plate is broken for sure. i'v seen that happen. you shouldn't be able to rock or slide the Torque convertor at all, if it seems to move independantly of the engine, then there's your problem. it's not really hard to change one either, a good weekend project. unbolt trans, slide it back enough to get the torque wrench back up there and your set.1963 Oldsmobile Dynamic 88 Holiday
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by 1987cp View PostAs in, they're cast in one piece and then split apart with a chisel so the caps only go back on one way?
Originally posted by 1987cp View PostNice to know the problem! Fixing is a bit of a pain but straightforward.
What breaks flexplates, anyway?
Originally posted by Grandpaslincoln View PostMetal fatigue, probably caused by abuse. I can imagine someone doing neutral drops or something, would jar more than the transmission.1963 Oldsmobile Dynamic 88 Holiday
