The charging system has nothing to do with starting the car!!! Your lights will not go out from the alternator. When switching the starter on, all current is routed to the starting circuit, all lights and accessories shut off. That is normal. Now do you get any indicator lights that say that the charging system is malfunctioning? An amp light? A volt reading or something? The need to jump the car everytime you need to start it? Do you have access to a volt meter that you can hook up to your car to see if the alternator is putting out any volts?
Try this one, after the car's been running for a while, shut it off and start the car again, if the car starts right up with no trouble, you have verified that That the surface charge on the battery, supplied by the charging system was enough to overcome the resistance that is probably hiding in the starting circuit. Be it a dirty or loose connection, Broken wires or a tired starter motor. You could also do the same things with jumper cables, I had a similar thing when my engine was hot where it would crank slow, it was actually my battery was bad. When I hooked up a jumper box or some jumper cables, the engine turned over fine. Fast, just as it would when the engine was cold.
