The only issue the car currently has is damaged oil valve seals(forgot the exact name right now) and the gas tank which holds to much pressure. When I open the gas cap I could see the gas from the gasoline escaping.
1992 Mercury Grand Marquis with bastard block.
1992 Mercury Grand Marquis.
Upgrades: Big Brake Upgrade, digital dash, Custom ignition Switch system, sequential tail lights, Teflon Fuel lines, LED interior lights, rear end rebuild with limited slip.
Future upgrades: 5.0 swap, 4r70w swap, aluminum driveshaft.
Originally posted by pivichot View Postone question. how much mpg does you car do Scott? Right now with the bastard block I am getting between 10-12 in city.
valve seals and an evap problem. get a new gas cap and see if it fixes that.sigpic
I already changed the gas cap and it didn't fix it. Does the gas tank have a valve that can become clogged? Also what do you mean by Evap?1992 Mercury Grand Marquis.
there is the evap solenoid that may be bad, or maybe the charcoal canister or it's plumbing is damaged. i think the solenoid hangs out near the battery, and should be in a vacuum line that runs between the manifold and the box that lives under the battery. Evap is evaporative purge, basically the system that sucks the fumes out of the tank and burns them in the engine.86 Lincoln Town Car (Galactica).
I did remove the Evap solenoid once but there was still pressure and I have disconnected the charcoal canister to see if that helps. It didn't.1992 Mercury Grand Marquis.
if you pop the rubber line off where it hooks to the steel line along the frame, does it vent? If not, the problem is back at the tank itself where the hoses all hook up. I seem to recall a check valve built into the plate where the 3 lines hook in. If the check valve is gummed in place, the vapors won't get up front to the evap system to be sucked out.86 Lincoln Town Car (Galactica).
The three lines? near the 2 fuel lines? If the check valve is damaged is there a fix or do I need to install a new tank?1992 Mercury Grand Marquis.
duh, i'm an idiot. The vapor line goes to a seperate connection at the very top of the tank. it should just push into a grommet if I'm not mistaken. You may need to drop the tank to get it out tho, not sure. Likely flushing it out with carb cleaner would fix the problem though. Not much to that check valve, just a plastic body with a little plate in there.86 Lincoln Town Car (Galactica).
Thank You.1992 Mercury Grand Marquis.
Well it has been over a year and I am finally trying to start buying the parts for the project. I was going on putting pi heads and rebuilding the bastard block. Now I have several questions and hope to get a hint or pointed to the right direction. If I were to go with the 302 which is the best 302 engine to go with. I would like to go with a 5.8 but I am thinking fuel mileage. I know performance and fuel efficiency don't mix well. My project consists of the following
1. engine. Options are 302 or rebuilt 4.6 with pi heads.
2. Transmissions I would be sticking with the AOD and rebuilding it with 4r70w parts. To get the wide ratio and also going with a (most likely) manual valve body.
3. Ecu I am planning on megasquirt. Still don't know which and most likely will have to have it tuned by a shop.
4. For brakes I am doing the front brake upgrades to the 98 brake system.
5. For the differential I am thinking of 3.55 or 3.73 to keep good city mileage.
6. For the driveshaft is there one that is aluminum that is a direct swap for my 92 grand marquis?
For the 302 also is there a link for basic bolt-ons to increase horsepower. Also I am going with dual exhaust.
The car is for driving everyday since I go to the university with it but also want a car that I could take to the drag strip to just run it.
Here is a picture of what the car looks like now.
5. 3.55s are good.
6. As long as its has the same splines on the output shaft, you can swap in an aluminum driveshaft (or mma: metal matrix alcoa). You WILL have to swap out the output shaft housing, because the outside diameter of the yoke is larger, and will not fit in the current output shaft housing.
I think it'll work. Or someone correct me.
I know it works with the AODE.
There are going to be mixed responses until you pick a motor to go with.
I would also suggest going with the 5.0.
03 Mercury Marauder- 63k
Did you patch the holes in the rear doors yet?
Looks nice. What color?
And can you pleasr take a pic showing the front corner? (And/or start a Readers Ride thread)
Patches are just covered by small.american flags. will cover them this year. coloris rustoleum flat black but after the project will go with gloss black or john deer flat black. will do.1992 Mercury Grand Marquis.
Also i am most likely i am goig with the 302. But wanted to know which are the years i am should be lpoking for. i can buy a rebuilt engine for about 1600. If i am going to do it better do it good.1992 Mercury Grand Marquis.
