My wifes vic is having some issues with starting on cold mornings say below 45* or so. You can hear the fuel pump kick on when you turn the key and the engine isn't turning over plenty fast no different then when its warm. But it takes 4 or 5 tries before it will want to fire. Once its running there is no problems for the rest of the day. Any ideas?
2006 P71 cold starting issues
1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
sigpicTags: None
could be plastic intake manifold gaskets. I have this problem on my windstar. when it gets cold they contract and suck air when it gets hot they expand and seal. It throws 171 and 174 code when it gets cold and runs rough. in the summer the code goes away
WARNING: Above advise is based on actual experience or just plain common sense. In the event said advise is determined to be incorrect you are entitled to a full refund of exactly what you paid for it.lol
85 LTD Crown Vic Coupe 302 CFI Dual Exhaust No Cats Thrush Welds
pwr windows, locks, seat, antenna
cruise, tilt, white on white, maroon interior
Fuel filter. Dirty injectors. Crap battery.
Or it just doesn't like the cold.
My Town Car nearly dies on start up in the cold (as of recently), but I attribute that to the crap battery that's been drained several times.
03 Mercury Marauder- 63k
Ok this thing is driving me nuts. Battery good, changed spark plugs, tps, cleaned throttle body. It gets fuel, air so Im thinking spark. It doesn't fire for several tries then its like a light switch got turned on and the car runs perfect. Don't know what to try next.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Plugs and all didn't improve it at all?
I'm guessing there's probably no codes. I guess you could check to make sure there's spark first thing on the first attempt of the day, I'm wondering if the ECM isnt allowing spark for a certain amount of time for some reason, but i'd still be suspicious of a fuel filter or something like that.2003 Crown Vic - Stainless Works Longtubes + 2.5" exhaust, 19" C/S Wheels, 70MM TB
2004 Dodge Ram 2500, Yeah, It's got a Hemi
2000 Dodge Dakota Quad Cab
ECM relay?
Its gotta be a spark issue. I tried a shot of starter fluid with no affect. Last night I swapped the ignition and a/c relays to see if it that would do anything. It started right up today but it also wasn't as cold out.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
