Okay, I've replaced the intake in my GM, now I need to burp the cooling system to remove the air from the system. What is the best procedure to do this without a vacuum set up? I see on the top of the coolant crossover that there is a plug right behind the thermostat housing, I presume I can crack the plug as the car is coming up to temp to purge the air from the system, right? Tips and tricks welcomed!
Intake replaced, next steps...
Perform the procedure you outlined. Let it cool, add fluid in all places possible. Then turn on, let it warm until the thermostat opens but before the car gets hot due to air in the engine, give it a quick run up to full throttle, in 1st gear, once or twice, traffic permitting. That seems to move the bubbles out of the nooks and crannies. It must be very close to where you are working as engine temp may then go up due to air in system. So you will/may need to park right after the run. Let it cool and add fluid as necessary.
After that you can probably drive it normally, go for a non-critical drive, just keep some fluid in the trunk and keep an eye on the gauge. If it all seems good, end the ride with a 1st gear run up, could not hurt, traffic permitting. Then you could check for bubbles and fluid level after it all cools.Last edited by jaywish; 02-21-2013, 01:28 PM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Well... She runs, and the heat works, and there don't seem to be any leaks. That's the good news. Bad news, though, is that she's got a miss. I know the alternator and at least one of the coil packs were both getting showered with coolant when the leak became a crack, so I'm thinking my miss may be due to a weak coil pack. This is less than good news because the coil packs are like $67 each! I know that when I removed the old intake, I did spill some coolant down into the intake port on the head, I blew all I could out with an air compressor before installing the new intake, though. When I first started the car after the repair, it idled really rough, but she smoothed out with a little time. Is there any hope that this little miss will work itself out as I drive? It isn't bad enough to throw a CEL or anything, just feels like poop when accelerating.
2000 Mercury Grand Marquis GS HPP - SOLD
Wore out the cam chain tensioners and jumped time at 176k miles.
Good news! A few heat cycles, and runs through the RPMs, and she's continuing to get better and closer to her old self again! I think I've (at least temproarily) dodged the bad coil bullet.
Did that job about 2 years ago, wasn't fun lol worst part was that protector thing for the fuel line on the back of the motor. I have seen performance coils from MSD for less then what you had mentioned for the coil, so if it does go bad you may want to shop around. Jegs also has their own brand performance coil for like 30$ a piece.
I might have conisdered changing the spark plugs after the manifold change. Well, after you started it up and burned all the excess cooland out of that #5 cylinder.
I have not heard anything bad about the Jegs COPs yet. It could be an option. Summit has their own brand as well.
Glad to hear it's running well again!
-ryan s.-08 Lincoln Navigator L - 233k
03 Mercury Marauder- 63k
