I know you guys are going to start jumping all over my shit, but I started to use Lucas oil stabilzer(not the sythetic type) since about 180K miles. My car now has 250K miles. Basically the car doesn't burn any oil at all, and still gets 22-23 MPG. I don't care what anyone on the internet says, the stuff works for me. Hey, give it a shot and if it doesn't work for you then don't use it. I'm getting '01 Mustang GT heads pretty soon so I guess I won't have to do the seals...
burnin oil
Originally posted by p71townyIt will run just fine. Its just annoying. The use of 10-30 mobile one slowed ange's consumption. It starts burning fast when its due for an oil change tho. Also check you pcv, don't want to loose any more oil than necessary.
Originally posted by JohnnyirocNo one with a 4.6 should use anything other than 5w30 or 5w20...10w oil is asking for problems. Lucas is fine for other things, but will only mask a problem for a short time with a 4.6. It is like adding thick gear lube instead of oil to the engine. OUR ENGINES WERE NOT DESIGNED FOR THICK OIL! Run too thick and you will be replacing heads-cams trust me.
In extreme cases it works, but not in most.
I try to avoid statements like "No one with a 4.6 should....."
All I can say is what works for me. Nobody has to take my advice.
My shit runs good.My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
lucas is good shit......i use it in everything including the 95 turd........keep your thin ass motor oil, i've known people to use 15w40 in cars, and the motors last for hundereds of thousands of miles.......i use 10w30 and a qt of lucas every other oil change
4.6 motors are supposed to use thin oil tho, something about small oil passages or whatever. I guess once its got miles and some wear on the parts you can get by with thicker oil to take up for it. My truck says 5w30 and if I run thicker the lifters tap and rattle in the winter. I just go with whatever the manual says to use.86 Lincoln Town Car (Galactica).
Originally posted by gadget734.6 motors are supposed to use thin oil tho, something about small oil passages or whatever. I guess once its got miles and some wear on the parts you can get by with thicker oil to take up for it. My truck says 5w30 and if I run thicker the lifters tap and rattle in the winter. I just go with whatever the manual says to use.
I understand what the factory recommends but again, I go with what works for me. I think the newer MOD motors are different, they run even lighter oil than the older ones.My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
I won't get into the whole 5W-20 vs 5W-30 thing. You can search CVN for all the opinions you could ever dream of on that subject.:worship: Aeros r00l.
Originally posted by BMFerI've never run anything but 10W-30 in our fleet, including in brand new motors. How am I getting 400-600K out of 4.6's? 10W-30 is no thicker than 5W-30 except in cold temps. Further north, sure, run 5W. South of the Mason Dixon line, there's few places that ever get cold enough to require 5W oil.
Originally posted by mephistophelesYeah, or one could do a bit of research and understand *gasp* what the numbers mean. But then one would have to understand viscosity and all the mumbo-jumbo science shit. Opinions, however, are far better.
You mention opinions, but the statements are NOT based on opinions, they are based on my personal EXPERIENCE, and I think he just proved that his are based on his personal EXPERIENCES.
People usually don't just wake up one day and decide that they're going to just start running some strange weight of oil.
Different people have different experiences with different cars.
Can't we all just get along and let each owner run what works for them?
Why does it have to degrade into the old third-grade "you-aren't-doing-exactly-what-I-would-do-so-you're-wrong" type of mentality?My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
When I was young(and dumber), I ran 20w50 in my 89 Lesabre
w/3800 V-6. I even ran it into the winter until I got around to changing to a thinner 10w40. Made some nice knocking sounds in the morning when cold out.
It had 200,000 miles when I dumped it(bought it at 68,000). Still ran fine, no knocks/oil burning or leaks. Good oil pressure. AND at that point, I had made the switch back to 10w30. Ahhh, the good ole days......
I use 5w30 full(fake)synthetic Valvoline in my Merc. Has worked fine, so why change the weight to 5w20 now? But one change I am going to make is to switch to that extended performance Mobil one stuff. No place to change my oil here and taking it to the shop is WAY too much. I'll just change it when visiting the parents and let er go 8000 miles or so, fuck it.1995 Grand Marquis LS, digi dash, loaded
124,000 miles
Mods:99 PI steering gear, harsh rear IAS shocks, front KYB gas adjusts, HPP rims with Bridgestone Potenza G009's, Walker dual exhaust with direct fit Magnaflow cats
Originally posted by mercenvyI'm pretty sure that BMFer understands what the numbers mean, as do I and a lot of other people in the Panther community.
I have personally worked on 3 panther cars where too thick of oil caused the cam to wear out the head castings cam bearing surface. There are no bearings in the cam/ heads such as in your rod caps and mains. So when they wear you will replace the whole head. The rockers fall out if it wears out enough.
