dohc 4.6 engine swap
    mustang 4.6 swap...
    ...into a '94 GM:
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
      looks rusty
        Originally posted by torquelover View Post
        Seemed the huge heads on the 32V 4.6 wanted to occupy the same space as a box's UCAs when I pulled the tape out. A 2V would clear no problem.
        while a 4v valve looks alot wider than a 2v, it isnt
          tight fit in the marauders
            if you look at a 2v in a 96-04 mustang, you'll understand, that you cant fit anything wider in there, and those cars came with 4v's also
              oh god yes. thats why the 5.4 4v's dont fit. They're too tall.
              To even put the ford gt heads on the 4.6 4v requires extensive modification to the wiper tray and the hood. because they will not fit under a stock hood.
              The one guy i know with a marauder that did that had a sweet 2.5" steel cowl hood made. It looked like the stock hood, except it buldged a little more. And the only way you could tell that it wasn't stock was to park it next to another marauder/whale.
              08 Lincoln Navigator L - 233k
              03 Mercury Marauder- 63k
                If you were going to go with a Mark VIII engine swap why not just spend the extra quid and go with a SVT engine? Or can the aluminum 6 bolt main block from a Mark VIII be built to make the same hp? I don't know, I am trying to figure out what would be better myself
                  The SVT Cobra motors are roughly $4000 used. Mk8's are about $150 at the jyard.
                    for what it costs to port PI heads, Im not sure its worth it, they only pick up about 15hp ported
                    PI heads themselves are good upgrade over npi's
                      I'd like to 4.6 a Pinto wagon...I'm sick and twisted...
                      95 Townie under constructionsigpic
                      75 Merc Meteor wagon (rust in peace)
                      81 GM Tudor (flat as a racoon on the Trans-Canada)
