So I discovered what the problem with my VSS in the 93 vic is... either the driven gear is binding up on the VSS itself, or the output shaft teeth are not engaging it very well... either way, it's slipping and not actually being spun properly (lack of teeth engagement). What would cause this? Is this an indicator that my output shaft is loose on the transmission? (it is the original AODE, but it was rebuilt at 120K, though it has over 220K on it). That would explain a lot of the issues with the car actually.
The way I found out was I spun the tires a little taking off from a light and as the car moved on down the road, it took a while for the speedo to tick up to the speed I was actually going.
