03 Town car ATF leak?
Hard to tell.
03 Mercury Marauder- 63k
Looks like seepage out the VSS on the tailshaft housing. Mine would scare you. They're both coated completely in everything.
Doesn't look like enough to be scary, whatever it is. VSS or OSS is a pretty good guess.86 Lincoln Town Car (Galactica).
since its an 03 car, the VSS is not used. there is a plastic plug thats bolted in place to cover the hole. The oring on the cover has gotten brittle from heat and is no longer sealing. its fairly easy to fix the leak. use a 7/16 socket/wrench, remove the retaining bolt and remove the cover, remove old o-ring, install a new oring. clean the area with brake cleaner (optional) lubricate new oring with ATF, transmission assembly lube or vaseline and install cover, install and tighten retaining bolt.
