Need to verify if the radio antenna is integrated into the back glass or front. Needing a new windshield by the end of Sept. and want to be sure I don't have it in the front glass.
Location of integrated radio antenna 03 Sport
These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.Tags: None
pretty sure its in the back. Most of them will say "radio antenna" right near the wires for it. Most of the time its the set of wires towards the top.86 Lincoln Town Car (Galactica).
Position of antenna cable
HI,
if you look into your trunk: onto the shelf, right hand from the spare tire and further right from the trunklid hinge: there is a black antenna cable running from the rear window to the front. If you want to go further: you can find an antenna cable connector right behind the rear seat.
If you have that cable there, your 2003 has a rear window antenna.
Hope that helps
Greets from Germany
JoJo
Yeah, It's in the rear windshield.
03 Mercury Marauder- 63k
Thanks guys. One other thing I just noticed. Is the front reveal moulding a 1-time use thing or can it be saved and reinstalled w/ the new glass? I haven't tried pulling the moulding out myself just yet and don't want to destroy it if it can be reused.
I will be removing all the interior/exterior trim I can ahead of time to save it from getting torn up by the glass guy. My only worry is the dash pad, which they will replace it I see even a scratch on it when he's done. Yes, I am that picky about my car, lol...These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
Originally posted by FordMan77 View PostThanks guys. One other thing I just noticed. Is the front reveal moulding a 1-time use thing or can it be saved and reinstalled w/ the new glass? I haven't tried pulling the moulding out myself just yet and don't want to destroy it if it can be reused.
