Hello my mgm when first started beeps 5 sets of 5. Then while driving it randomly does it again like every 30 min or so
2001 mgm mystery 5 beeps
Is your airbag light on? I know if the module has an open loop or is busted, it makes the beeping noise and the light comes on.
03 Mercury Marauder- 63k
+1 airbag light burnt out... so now it's beeping at you.
My 94 F150 started doing it. Turned out to be the clockspring in the steering wheel. It was worn out enough to trigger an airbag warning code.sigpic
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
Yes I always wear my sealtbelt. No the airbags light is not on it maybe burnt out then again it may be the module because it still beeps when I swapped to a 140 mph speedo which I had to swap back out since I apparently grabbed the wrong year cluster. Would anyone suggest going to a pull a part and grabbing one out a different year mgm. Most. Mgm are an older year model like 95-97 and the cvpi are from 01-05 but the bags are all popped open on them. So would buying a brand new one be better? Also how would I check the clockspring in my steering wheel?
