Hey guys it's been awhile since I've posted but I still browse on the site from time to time.
Anyway I'm having an issue with my Lincoln. No brake lights are working and the shift lock actuator won't disengage.
I have replaced the brake light switch on the pedal and the problem is still not fixed.
I have checked all fuses that are in the same circuits (shown in my evtm). And I am getting 12 volts on the switches hot feed and 12 volts from the other feed when I press the pedal so I know the switch is working.
But I get no voltage to the shift lock and no voltage to the brake lights. What's weird though is I do get voltage in the fuse box when the fuses are removed and I press the brake pedal. But once I put the fuses back in I get nothing.
Can anyone offer any advice? Thanks.
