Computer questions
    Computer questions
    Would a computer from a ‘99 CVPI work plug and play in an ‘03 grand marquis? Assuming that I take the 140mph cluster also? I have a 120mph cluster but have changed my rear end from a 2.72 open to a 3.55 lsd and my current speedo is fast by 16% and predator says they don’t make a tuner for anything older than the 05 grand marquis so I can’t just get a tuner and mess with it myself.
    The cars are functionally the same as far as I can tell. I don’t know about the harness but all the same things are in all the same places.
    Short answer is no. There’s a lot that changed between those model years.
    My Cars:
      Tuners exist for older than 05. I know multiple people personally who have cars in that range who have fixed their speedometers with available OBD2 plug-in tuners. Unfortunately I don't know what brand but they're out there. Check with the Marauder guys. Those are all 03-04. Not the same ECM but they might have a brand for you.
        The cluster does not matter, both the 120 and 140 versions read the same speed sensor output and will read the same.
        Not sure about plug and play for the '99 ARA3 PCM into the '03 car. Although, I believe if the particular ARA3 PCM you have/obtain was from a car with 3.55 from the factory then the PCM is all you need.
        Edit: nevermind, it looks like not plug and play, see the other posts.
        Vic
          PCM will not work.
          Talk to Marty and get a tune.
            The PCM will plug in... It will try to work, but it will report tons of errors. The transmission has a different ring gear with 24 teeth instead of 6 holes for the output shaft sensor to read. This will end up confusing the PCM and making it run in limp-home mode and may lock the transmission into 2nd or 3rd gear (can't remember what the worst limp home mode is). The engine is also a little different and uses a different MAF sensor along with different injectors and the engine may not even run for that matter. Tuning the currently installed PCM is a much easier option and can be done with SCT, HP Tuners, or Core Tuning setups. Marty at Mo's speed shop is definitely a safe bet.
              No. The ecm will not work. The way the fuel pump is controlled is completely different. 03 introduced the fuel pump driver module. 99 still used a fuel pump relay. There are differences in how the transmission is (inputs and outputs). Amongst other things.
                Hence reporting tons of errors. I forgot about the fuel system change though.
                  isn't there a PATS thing somewhere in the mix as well?
                    CVPI PCM ignores the PATS. So if one was to get it tuned to work with the car, it would lose the PATS function.
                      However, I think you can enable PATS with a tuner. You can disable it on other ecms if I'm not mistaken.
                        Yes, I can confirm this with my current cars.
