Here is the relation by blade cross section area solved for blade diameter.
Let's go back to the suzuki aerio engine since that seems to be merc91's favorite.
2005 Suzuki Aerio 2.3L DOHC engine = 65mm bore/60mm blade
60 mm / 140 cid = .4286 mm/cid = 129.4 mm for a 302
4.38"2 / 140 cid = .0313"2/cid or 9.45"2 = 3.47" Blade Dia. or 88.1mm for a 302-Still looks pretty darn close to 90mm don't it? And this is factory OEM non-performance emissions compliant stuff, all these cars im sure gain performance with larger TB's. Not that the performance aftermarket for suzuki aerio's is even existant for all i know, lol but the point still stands.
1995 Mercedes Benz C280 2.8L engine = 70mm bore/70mm blade
70 mm / 171 cid = .4093 mm/cid = 123.63 mm for a 302
5.97"2 / 171 cid = .0349"2/cid or 10.54"2 = 3.66" Blade Dia. or 93.0mm for a 302
1990 Toyota Corolla 1.6L DOHC engine = 57mm bore/56mm blade
56 mm / 98 cid = .5714 mm/cid = 172.60 mm for a 302
3.82"2 / 98 cid = .0390"2/cid or 11.76"2 = 3.87" Blade Dia. or 98.3mm for a 302
I can do this all day guys.
